PORT C as digital inputs
8 posts / 0 new
Hi all,
I have been usig timers, the UART, ADC ports of my ATMEGA16 successfully for quite a while now. I now want to use digital inputs for the first time and am failing. I studied the datasheet but I can't figure out what I am doing wrong.
I am doing
        cbi(DDRC,PC1);                  /* digital input */
        sbi(DDRB,PB5);                  /* digital output */
        while (1)                       /* loop forever */
         if ((PORTC & _BV(PC1)) > 0) sbi(PORTB, PB5);
         else cbi(PORTB, PB5);
and would like to see the PB5 LED of my Arduino board to glow when I touch PC1 with a 5V wire. But this does not happen. THE LED is OK (I can switch it on programmatically). I tried other pins (ports) as well as input with the same result. I am putting a TTL signal on the input pins, so I don't need no internal pull-up. If I do
sbi(PORTC,PC1); /* pull up*/
to activate the internal pull-up, reading the pin gives me a high although I am dragging down the pin externally to ground!??
What am I missing?
Thanks a lot,
Andreas
Use internal pull-up on PC1 & connect a switch between PC1 and ground.
DDRB=(1<<PB5);   //output
PORTC=(1<<PC1);  //input with internal pull-up enabled
   if (PINC&(1<<PC1)==0)
      PORTB|=(1<<PB5);
      PORTB&=~(1<<PB5);
By and large it is safer to ground things than to connect them to Vcc. This is probably why ATMEL have internal pull-ups and not pull-downs.
Thanks Stefan...PORTC changed to PINC :oops:
Lee -.-
..apart from the Xmegas. :wink:
And for reading the input use PINC (not PORTC).
Stefan Ernst
^ You found Waldo!
Where X is a has been or an unknown quantity! :)
Lee -.-
The one with the X makes an excellent conroller for a new and improved mouse trap. :)
Hi Stefan and all,
Thanks for your helpful comments!
That was the problem! It's working now!
Thanks a lot,
Andreas
