create/program "Image" including bootloader?
3 posts / 0 new
Hi there,
most of my projects require to be updatable, therefore they have a bootloader which is programmed via an ISP or JTAG adapter and the main program is uploaded via serial connection lateron. Isn't it possible to create a kind of image containing both bootloader and main program and program it into the right place so that only one step is needed for the start?
Thanks for any comment,
Mat
The bootloader tutorial ( https://www.avrfreaks.net/index.p... ) contains a section named "How do I program both the application and the bootloader?"
quick and to the point, thanks very much Johan :)
