Custom Bitfield & Port Mask
3 posts / 0 new
I would like a more elegant way to address a 16bit peripheral when using two ports. I have no idea how I would go about it but is it possible to do this:
MY_PORT = 0x99FF;
that would output data as:
PORTA = 0x99;
PORTD = 0xFF;
Or even better if I could have bit control and arbitrarily output all 16bits to any port/pin combo.
I know ARM's have a port masking register and its easier when their ports are 32 long but is their any easy way to do this on an AVR?
#define MY_PORT(val) {PORTA=(val)>>8; PORTD=(val);}
    MY_PORT(0x99FF);
Yea... That not quite what I was after. I am currently doing this in my routines but would like a better method that allows me to use pins from wherever I want to. I figured it would need to be a structure of sorts.
I have no idea if the example below works but I figure it will be something like it
struct bits {
  uint8_t b0:1;
  uint8_t b1:1;
  uint8_t b2:1;
  uint8_t b3:1;
  uint8_t b4:1;
  uint8_t b5:1;
  uint8_t b6:1;
  uint8_t b7:1;
} __attribute__((__packed__));
#define SBIT(port,pin) ((*(volatile struct bits*)&port).b##pin)
struct MY_PORT {
  SBIT(PORTA, 0);
  SBIT(PORTD, 4);
  SBIT(PORTB, 3);
  SBIT(PORTB, 6);
MY_PORT = 0x99FF;
