Converting asm function to C - Problems
7 posts / 0 new
Ok so I have some example code of how to convert an long long int into a string of ascii characters. I have simulated it in studio and made a flow chart on how it works. I then wrote a C function to try and get the same results.
My problem is mainly that in asm you can use overflows in the temp registers easily yet in C is it much harder. I built a union that if packed properly should allow access to the whole value plus access to each byte segment.
I believe this is how the asm works:
- Value is loaded into r22:r25
- left shift value and if r26 overflow is > base, subtract the base
- after 32 shifts if r26 > base then subtract 7 (no idea why...)
- subtract ascii 0 from r26
- push the result onto the stack for later
- repeat untill r22:r25 = 0
My union packs the bits so that r26 is the equivalent of accu.mByte[4]. The problem is on the first shift ( accu.total = accu.total << 1; ) the program quits (goes to end of main and halts)
I have no idea if I am doing this right as this is the first time I have tried to convert asm to C.
; Extended direct numeral string output (32bit version)
;Prototype: void xitoa (long value,	// value to be output
;                       char radix,	// radix
;                       char width);	// minimum width
;Size: 59/59 words
.global xitoa
.func xitoa
xitoa:
				;r25:r22 = value, r20 = base, r18 = digits
	clr	r31		;r31 = stack level
	ldi	r30, ' '	;r30 = sign
	ldi	r19, ' '	;r19 = filler
	sbrs	r20, 7		;When base indicates signd format and the value
	rjmp	0f		;is minus, add a '-'.
	neg	r20		;
	sbrs	r25, 7		;
	rjmp	0f		;
	ldi	r30, '-'	;
	com	r22		;
	com	r23		;
	com	r24		;
	com	r25		;
	adc	r22, r1		;
	adc	r23, r1		;
	adc	r24, r1		;
	adc	r25, r1		;/
0:	sbrs	r18, 7		;When digits indicates zero filled,
	rjmp	1f		;filler is '0'.
	neg	r18		;
	ldi	r19, '0'	;/
				;----- string conversion loop
1:	ldi	r21, 32		;r26 = r25:r22 % r20
	clr	r26		;r25:r22 /= r20
2:	lsl	r22		;
	rol	r23		;
	rol	r24		;
	rol	r25		;
	rol	r26		;
	cp	r26, r20	;
	brcs	3f		;
	sub	r26, r20	;
	inc	r22		;
3:	dec	r21		;
	brne	2b		;/
	cpi	r26, 10		;r26 is a numeral digit '0'-'F'
	brcs	4f		;
	subi	r26, -7		;
4:	subi	r26, -'0'	;/
	push	r26		;Stack it
	inc	r31		;/
	cp	r22, r1		;Repeat until r25:r22 gets zero
	cpc	r23, r1		;
	cpc	r24, r1		;
	cpc	r25, r1		;
	brne	1b		;/
	cpi	r30, '-'	;Minus sign if needed
	brne	5f		;
	push	r30		;
	inc	r31		;/
5:	cp	r31, r18	;Filler
	brcc	6f		;
	push	r19		;
	inc	r31		;
	rjmp	5b		;/
6:	pop	r24		;Flush stacked digits and exit
	rcall	xputc		;
	dec	r31		;
	brne	6b		;/
	ret
.endfunc
void myitoa(long value, int base, int length)
	unsigned int byte_cnt, shift_cnt;
	char buffer[34]; //32bits + sign + terminator
	typedef union{
		long long total;
		struct{
			unsigned int mByte[5];
	} itoa_conv;
	itoa_conv accu;
	accu.total = value;
	byte_cnt = 0;
		for(shift_cnt = 32; shift_cnt > 0; --shift_cnt)
			if( accu.mByte[4] > base )
				accu.mByte[4] -= base;
			accu.mByte[4] -= -7;
		accu.mByte[4] -= '0';
		buffer[byte_cnt] = accu.mByte[4];
		byte_cnt++;
		if( (accu.mByte[0] + accu.mByte[1] + accu.mByte[2] + accu.mByte[3]) == 0)
			break;
	if( byte_cnt < length )
		buffer[byte_cnt] = '0';
		byte_cnt++;
	for(; byte_cnt <= 0; --byte_cnt)
		xputc( buffer[byte_cnt] );
	accu.total = 0;
Your example is 32 bits - "only" long int.
Why don't you use ltoa? http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#g1d4c7b84110553544081a69a0fc49c52
/Martin.
I am in fact trying to create my own itoa() (Why? Because I want to implement it in a particular way!)
Is my C version the same flow as the asm version? I still have not got it working...
In general even writing my own C function and ignoring the asm I am unsure how to convert a long into a string. But I have been stepping through asm all day and feel kind of dumb.
But why is itoa_conv.total long long (64 bits)?
And I cannot see, why this function should/could work.
static void reverse(char s[])
    uint8_t c, i, j;
    for (i = 0, j = strlen(s)-1; i '9') {
             *s += 'A'-'9';
        s++;
    } while ((n /= b) > 0);
    s++ = '\0';
    reverse(s);
/Martin.
I required a 32bit value to hold the value and after 32 left shifts and the - base maths the conversion of the value to ascii was done on the bits 33-40.
32bit Value in r22, r23, r24, r25
ops done on results in r26.
I did not know how to append a byte onto a long so I just use a long long for testing.
I will try out your code tomorrow, im to tired to tonight. Thanks for the response though, I will let you know if it works for me.
BTW, the code posted by me above is for unsigned and does not handle the sign. But it should not be to complicated, to handle the '-'.
/Martin.
This thread may be of great interest:
