Studio 4.08 project window problem
6 posts / 0 new
Can anyone confirm that this is a real bug, and not just a 'made by Lyle' problem?
If I start a project in 4.08, and add files to the project (either create new or open existing), no problem.
If I then delete a file from the project, any further attempt to add a file results in an error message. Using the key with focus on the project view window results in a "Error gettin node 20" message, and using Project>Create new file or Project>Add existing file from the menus results in an "Error selecting xml-node 01" message.
I don't get these problems in 4.07, but this is to be a Tiny13 project (which isn't supported by 4.07). And WHY WHY WHY WHY can't I use Studio 4xx to continue to do work with the Tiny15 and the 90S1200???
(beware, rant follows)
There is another thread currently running where the author has taken a fair bit of flack for criticising Atmel for releasing buggy software. I'm on his side. There is no caveat that this development system is intended for hobbiest use only, and I don't think that it is reasonable to put up with this sort of performance. I use this software for professional work, and have lost a fair bit of time on this "upgrade." This, in addition to the fact that I must now run 2 different versions of software to continue to support existing products and that the firmware upgrade to the STK500 is not bacward compatable with Studio 3.55 has left me fuming.
In anticipation of the "what do you expect for free" and "real professionals buy expensive software" comments likely to be generated, not every company has a budget for expensive development systems, and not every product justifies the expenditure.
Try upgrading the xml-parser:
http://www.microsoft.com/downloa...
admin's test signature
Thanks for the suggestion anonomous person. . . but it made no difference. Things are fine until I delete a file from the project, then back to the previously reported errors.
There seems to be a work-around. Close and re-start Studio after deleting a file from the project.
GRRRRRRRRR.
I would like to have a dollar for every time someone here has mentioned having to shut down Studio and restart it. Hell, for that matter I would like to have a dollar for every time I have done that :-)
Steve
Hello Lyle.
I've tried this with 4.08 and avr studio configured as tiny13 simulator.
I used these steps:
created an assembly project with a new assembly file using project->new project
wrote some nops in the asm file and saved.
Added existing files to the project using both the context menu inside the project window and the menu items in the project menu.
Removed files using the delete button or the context menu.
I did this several times, but I experienced no problems. I also tried to enter debug mode between adding and deleting files.
-Geir
Thanks for the input Geir. I have had some feedback for the Atmel dev. team. They have indicated that there have been other reports of this problem, but they have had difficulty re-creating it.
I have another work-around other than re-starting the program. If I put the focus on the word "assembler" in the project window and right-click I can add files through the pop-up menu without problems. Any other method (hot keys or Project menu) results in error messages.
Lyle
