Hi you all
I use a calculation in my program (with decimal numbers) but the value that is calculated is offcourse decimal and bigger than 8bits.
Is there a easy way to convert this in hex and split it into two 8 bit registers.
for example:
.equ Time=300/0.05
so time is 6000 dec
I use the attiny24 and do the programming in assembly.
Can anyone give me an idea how to do this?
Patrick
