no reset after JTAG programming ?
16 posts / 0 new
Hi people,
again I'm sitting on a new board this time with an Xmega and an AVRJTAGICE MK2. And I was wondering why the controller isn't reset after the re-programming. I was used to the behaviour of the AVRISP MK2 which I just could leave plugged to the board, program and then the new code starts. This doesn't work with the current configuration, I have to unplug the ICE and powercycle the board to start the code. Why is that ? I'm not sure about the reset thing at the JTAG and I should mention that I'm using a reset-controller on the board. Is it possible that the ICE actually tries to reset but can't pull down the line ?
Thanks very much for your hints and comments
Mat
Which tool are you using to program the device?
Doesn't really sound like a GCC thing.
Jörg Wunsch
AVR Studio 4.16, yes, maybe this is more general, sorry
you want to move the thread ?
Hey,
Are you using AVR Studio 4.17? I have seen the same there with a JTAGICEmkII, so it seems like this is a bug with XMEGA on 4.17... I've downgraded to 4.16 :-)
Are you using AVR Studio 4.17? I have seen the same there with a JTAGICEmkII, so it seems like this is a bug with XMEGA on 4.17... I've downgraded to 4.16 Smile
I had the opposite problem -- the reset wasn't issued until I closed the AVRStudio programming window in 4.16, but now works as advertised in 4.17.
- Dean :twisted:
I have the same problem. With 4.16 the board reset, in 4.17 it does not. Also be aware that the BOD voltage values are off by one for the XMega 128A1 in 4.16, so you could lock yourself out of programming a unit, as it will be permanently stuck in reset. This is fixed in 4.17. Also with 4.17 it doesn't crash every few minutes, like 4.16 did.
(ATTicket:556383) AVRStudio 4.17 build 666 holds reset until power is cycled avr[at]atmel.com to me Aug 3
Dear Customer,
I can not reproduce this issue on my STK600 + TQFT100 socket + JTAGICE mkII + ATxmega128A1 + AVR Studio 4.17 build 666. Is it possible to check with STK600? Also please check the Reset pin connectivity on the hardware.
Nothing change in "reset pin connectivity" between 4.16 and 4.17 in my setup.
Also be aware that the "old" JTAGICE mkII (rev 0?) does not work well with the Xmega series. Although I don't think it affects the reset behavior, it definitely affects the debugging behavior.
Stu
Mine says:
Hardware Revision: 0x01
Firmware Version: 0602 0602
What kind of speed did you get when single-stepping?
It might take 10 to 30 seconds to step between
a couple of NOPs on my setup. Was the same with 4.16 and 4.17.
bpaddock wrote:
Mine says:
That's the latest version of the JTAGICE - just wanted to be sure since we got some really squirrelly behavior with the rev 0.
We have not seen the kind of "slow stepping" you describe, or at least I don't think so or I would have heard about it. You've been around long enough, Bob, that I know you've tried all the basic stuff.
I do wonder if AVR Studio is not happy with the disassembly view. It seems they have been putting a lot of work on making the C source line debugging faster at the expense of the disassembly performance. Of course, if your source is assembly, YMMV.
I will check with the guy who has the most Xmega experience here to see if he has any suggestions (or commiserations).
Stu
Hi, I'm still using 4.16 and my JTAGICE mk2 is Hardware Revision: 0x01 and Firmware Version : 052c 052c . I didn't get the BOD thing, how can I lock out myself ? The fuses show BOD disabled.
I think the idea was that if you design an 3.3V system (where BOD, if used, would usually be set to 2.7V) that if you had it set to 4.x V as might be used on a 5V system that the Vcc would never get that high supplied from 3.3V so the CPU would never come out of reset.
To be honest I *think* you'd still be able to ISP it but I guess it's one of those experiments someone would need to do to see if that really is the case.
Obviously if there's a bug in the programming dialog in Studio for the Xmega parts and it actually sets a different BOD combination than you actually asked for then, if nothing else, this would be confusing and may mean you don't have the BOD protection you were hoping for. Wonder if anyone's reported this direct to Atmel?
You have to get Vcc above the BOD voltage, from experiance.
They know, as it is in the release notes for 4.17.
For ISP--no. For JTAG, I don't know.
From experience, I might have my STK500 set with VTG of 3.3V working on a dev project. Sally might walk in with half-a-dozen pre-production boards for another app that need new firmware. That app is a 5V app, with BOD set at 4.xV.
So I just jam on the header, and ISP away without changing VTG (during ISP the app is programmer-powered). No real problems, except that the app doesn't start after ISP 'cause it never comes out of reset.
Now, that is with my ISP programming software. I suppose that the ISP software could be written to check /RESET after it is released to see if it goes high. (IIRC /RESET goes low when in BOD?)
Lee
True. I'm dealing with XMega 128A1 with PDI and JTAG,
not ISP. Don't know about PDI. I do know with JTAG
you have to get Vcc above BOD, otherwise I'd have
some dead board, due to Studio's bad settings.
Hi, I know, this is an old thread, but I just updated to AVRStudio4.18 SP2 and the same thing happens again, I have to power cycle my board to start the new code. D.mn! Why isn't this solved/changed by now ? Or is there any special reason why this is supposed to be like that ?
