What is this trace geometry for?
7 posts / 0 new
I accidentally shorted something out with a screwdriver on my car stereo head unit, and it doesn't work anymore. I think I found the damage, but I'm not sure it's a fault, as it's really tiny, and I don't understand why the traces near it are shaped as they are.
I'm guessing that the oval, labeled "F01", is a placeholder for an optional SMD. For this part to be active, a tech could just 'burn' the thin trace, like I accidentally did, to make a voltage drop across "F01" (like setting a fuse bit - a real one).
Does this sound right? I'll just blob some solder on "F01", if so...
On the other hand, the "open circuit" may be part of the design - another placeholder for an optional part - and I need to keep looking...
I think F01 is a dual-circuit fuse. The void suggests one is "blown".
Perhaps this form of fuse is required by safety regulations to preclude sustained high current flow and fire.
I'd agree. Looks like there's been some soldering around the amp chip also.
I think perhaps its so the tech can repair the board with a busted track fuse.
For instance if the board fails during testing after assembly and the fuse goes, a simple drop of solder and the other fuse is brought into action. Better then scrapping the board.
oddbudman
Fuse traces - sounds like a good idea! They could have saved a board or two of mine, though I doubt my ability to etch that fine...
"F01" has been bridged, and I'll let you know how it works in a while (roommate stole the car). Thanks :)
It works perfectly. :)
wow, I love tech.
