Simple DC-DC with wide Vin
11 posts / 0 new
I need to come up with as simple a DC-DC converter as I can. There are a TON of chips out there that make nice simple converters, but I my problem is high/wide input voltage and space. It needs to be small and, hopefully, simple.
Requirements:
Vin: 20-75V (15V-75V would be even better)
Vout: 12V +/-5%
Iout: ~1A would be about all I would need. But 600mA should suffice if I can't get to 1A.
Ripple: Very low ripple isn't all that important. The AVR will be running behind a secondary 5V linear regulator.
Isolation: non-isolated. Design shares a common ground.
I could go linear using an LT3014B with an NPN pass transistor to handle current, but there's no way even a D2PAK transistor could dissipate enough power given my space requirements.
I've done some searching, but I might not be looking at all the options. Do you gurus have any additional thoughts?
Jim M., Rank amateur AVR guy.
National has the LM557x series controller. IIRC the MOSFET is internal, and all you need to provide is a Schottky and the inductor.
I like the TI PT5101A... wide input range
Have you considered using the Avr as the dc:dc controller?
Thats quite the wide input operating voltage in your spec.
oddbudman
oddbudman
Yes. I had considered it, but it's busy enough with other duties and I don't think it could run the DC-DC as a sufficiently high enough frequency to make the inductor as small as I'd like.
The LM5575 looks interesting I'll investigate it a little more.
The PT5101A is for old designs and their newer non-isolated offerings only go up to 38V. But a nice simple solution. Something like that 3SIP is certainly simple.
Look about LT1074,its a buck mode conveter.
You didn't mention low cost!
Lee -.-
Well YEAH. I want the world! Bwaha ha ha.
The overall cost of the project needs to be kept down. (Don't they all). I was hoping to be able to supply current to run auxiliary devices LEDs, LCD. Things of that nature without much hassle. A 3 pin SIP device that could do 70V down to 12V would be great. I found this one http://www.dimensionengineering.com/SWADJHV.htm but it's $25. Perhaps I'll design the board to just be able to run the AVR and FET drivers (~10-12mA) and leave a provision on the board to install one of these if the customer is OK with the up-charge.
High PWM frequency doesn't tie up the AVR, but rather how often you need to adjust the duty cycle. If you can get by with a free running ADC and a slow interrupt rate the CPU load would be minimal.
I can't use a free running ADC. My application uses the ADC extensively. But, yes, I understand what you're saying.
