Peter Fleury lib lcd & "°"
14 posts / 0 new
Hello
I'm using P Fleury Lcd Lib...(work good for me)
But i can't use the car "°" to display my temperature...
Have you an idea?
computer : GNU Linux / e6750
ship : Attiny 2313 / ATmega8
compiler : avr-gcc 1:4.3.2-1
Re-read your own post as if you know nothing already about the problem. Do you think you could answer it? How then do you expect anyone else to who knows even less about it than you?
Is the issue about how to convert the binary value in a variable to a string of ASCII numeric digits to display? That is given:
temp=23;
how do you output the characters '2' and '3' to the LCD? If so look at the C function itoa():
char buffer[8];
itoa(temp, buffer, 10);
lcd_puts(buffer);
Cliff
Yes : it's like this.
My problem is with this character :
(degree).
Is that in the HD44780 character set?
EDIT: actually looking at my copy of the Hitachi data, if the chip has character set A00 (mainly Japanese above 0x80) then there's a thing looking like degree in position 0xEF. If the character set is A02 then try 0xB0 which (superscript 0) looks as close as you can get.
Ah sorry, I was wrong about 0xEF in my edit above - it's 0xDF. So just lcd_putc(0xDF) when you want one.
This give me an alpha...
Make one for loop and see in wich position is the º char.
I'll maybe do the loop...
And do you how i can inclue this data in the programm :
http://www.quinapalus.com/hd4478...
Et keep cool,
for (;;) {
    lcd_puts(car);
    car++;
   _delay_ms(300);
lcd_puts refuse it!!
That's what I use in several apps.
Well is car a character type variable ? If so perhaps you should try using this function void lcd_putc (char c), because the documentation says that lcd_puts has the following declaration void lcd_puts (const char *s), hence it expects a string as a parameter.
As the picture of the character set you posted shows - "alpha" is at 0xE0 not 0xDF ?!?
Ok
I found my datasheet and it's B3...
