SPI fail
6 posts / 0 new
I have a real simple SPI function that reads by sending a dummy byte. I also have the uart up and running for debug work. This function comes from the Fatfs demo for anyone who wonders.
Anyway, the init function calls rcvr_spi 10 times to wake up the card or something, but it always hangs. I added the uart output to see what was happening and the best case so far is 5 transmissions with an average of 2-3 before freezing.
Why would the SPIF bit fail to set? I have no SPI interrupts enabled (I'm in master mode).
#define DD_MOSI   2
#define DD_SCK   1
#define DDR_SPI   DDRB
#define DD_SS   4
.....SPI init code
	DDR_SPI = (1<<DD_MOSI)|(1<<DD_SCK)| (1<<DD_SS);
	SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1); /* Initialize SPI port (Mode 0) */
//SPI receive via dummy send
static
BYTE rcvr_spi (void)
	SPDR = 0xFF;
	xputs(PSTR("SPI get\n"));
	loop_until_bit_is_set(SPSR, SPIF);
	return SPDR;
EDIT: also tried to go with a while loop in place of the loop_until_bit_is_set() macro thingy, no dice.
I can never understand why people have to complicate SPI. You only need a single function. You always have an in and an out. You just 'out' a dummy if you only want the 'in'.
unsigned char spi(unsigned char data)
    SPDR = data;
    while ((SPSR & (1<<SPIF)) == 0) ;
    return SPDR;
The FatFS code should work straight out of the box. Remember to implement the Card-Detect and Write-protect.
And of course wire the lines correctly.
p.s. I am well aware that ARM SPI can do some very clever things. The AVR can't. So why not keep it simple?
... Yeah it SHOULD work straight out of the box but it doesn't and that's why I am posting. The SPI function freezes after a few uses. I am running the demo on a mega64 and have all the connections done up properly.
Well, the code is written for a mega64. It DOES work out of the box.
Re-install the ZIP file and start again.
hahah... I can kill ANYTHING that makes sense in 2 lines of code or less!
In fairness to the OP, the fatfs stuff has the twin routines built. (And they work OK for me.)
Note that these are used along with a timeout. Have you set up the timing functions?
It is strange, as the wakeup is 80 dummy clocks. And master SPI should work fine.
You don't have a floating /SS by any chance?
