High side switch for 12 V
10 posts / 0 new
What is the best way to replace a manual switch and a thermostatic switch with switches controlled by AVR? These switches control 12 V signal and/or power (up to 1 A) and I'm not able to put a MOSFET between load and ground, but they do have common ground.
Is it possible to control a MOSFET switch on a high side of a 12 V system with 3.3 V AVR? How?
Using a relay would be straight forward, but I'm trying to keep the power consumption as low as possible. How much would a relay consume?
Are there any other options?
There is no "best" way... An easy solution would be for your AVR to drive the gate of a N-FET that has its source tied to ground, and its drain pulled to 12V with a resistor. The drain of the N-FET would also be connected to the gate of a P-FET. The source of the P-FET would be held high and the drain would be connected to the load.
When the N-FET gate is high, the FET is on, pulling the P-FETs gate away from its source, turning it on. When the N-FET gate is low, the resistor pulls the P-FET's gate to it's source, turning it off.
Maybe try optocouplers?
There are such things as solid state relays that can easily be drive by an avr even a 3V3 one.
Look up Clares optomos range for example.
John
If all else fails, read the instructions.
Similar to nleahcim, but example with a npn, not nmos driving a P channel mosfet.
No idea on load, inrush currents etc.. you need to watch these specs.
oddbudman
You could use a bistable relay; it has two coils, one to engage the relay, one to release it. Each coil only needs a short pulse. Disadvantage is that it won't release if power goes away.
Battery powered domestic thermostats usually have this kind of relay to control the central heater furnace.
What about an infineon profet
/Bingo
That looks very good!
AnalogicTech has announced the AAT4285, said to be the industry's first integrated slew-rate controlled lHigh side switch capable of supporting 12V operation. By integrating level shift and slew rate control functionality into a single device, the AAT4285 allows designers to reduce power consumption and minimize parts count in various new 12V application.
mikestrepps wrote:
AnalogicTech has announced the AAT4285, said to be the industry's first integrated slew-rate controlled lHigh side switch capable of supporting 12V operation...
I think others got there first. For example:
http://cds.linear.com/docs/Datas...
Greg
