How to connect ISP header with SPI?
6 posts / 0 new
I'm designing a circuit using the AVR's SPI, and also want to connect a 6-pin header for in system programming, which also uses the SPI ports. I've been unable to find anything about how I should connect the header, without affecting the normal operation of the SPI when not being programmed. Can anyone help?
Check application note AVR042
thanks, what resistor values should be used on the SPI lines? The note doesnt give values
Because they can't. You have to calculate / estimate the values depending on what you have connected to SPI.
Hmmm, I don't think I've ever added resistors to the SPI/ISP lines and I have many apps with SPI devices.
Use one of those resistors, a high-value one, to pull the chip select of the SPI device to the de-selected condition. Repeat for each SPI device.
For ISP purposes, SPI devices are "easy".
How do I calculate them? I'm interfacing with a radio module, what should I look for on the datasheet in order to calculate them?
