Do popular terminal emulators send strings or char arrays?
5 posts / 0 new
ie: Do they NULL terminate the character arrays?
By 'popular', I mean Hyperterminal and TeraTerm.
I am reading characters until I encounter '\0', and want to make sure this actually happens.
char * USART_Rx_str(char * FirstByte)
	char * LastByte = FirstByte;
	do {
		while ((UCSRA & (1 << RXC)) == 0) {};
		*LastByte = UDR;
	} while (*(LastByte++) != '\0');
	return LastByte;
I realize this doesn't check to see if it is writing into unallocated memory :P . Will have to look into that!
Depends on the terminal emulator program.
Most will send one Byte, (char) at a time. If you tic the box it will save them up and send them all at once when you hit "Enter".
You can have them include a Carraige Return or Carraige Return and Line Feed, when you hit Enter if you so desire.
No, terminal programs just send streams of characters, a null would not be sent unless it was deliberately part of the stream. The terminal programs are character based, not block based. So there is no need for a terminator.
The null terminator you are talking about is a C construct [other languages use it too] it is not a serial ascii transport concept. Unless some higher level transport is using it, but most ASCII protocols [ANSI/VT-100] do not use it.
Thanks. :)
In fact, most of the algorithms for sending a string of characters from a micro tests the character for a null, if not send it and increment the index/pointer. Thus, the micro will send all the characters UP TO and not including the null.
