Noob Question: EPROM File
10 posts / 0 new
VMLAB is refusing to complete a compile for lack of an EPROM file *.eep.
I lack any use for EPROM memory in a simple exercise I'm coding. So, what kind of dummy file can I use to satisfy the assembler?
Just add:
#include
char ee_var EEMEM = 'A';
to your program (I believe you use GCC?) and a one byte .eep file will be created when the project is built.
I should have mentioned it's an assembler exercise.
I tried just naming an empty file, test.eep. The assember still complained.
Which assembler are you using?
It would be hard for the assembler to complain about a missing .EEP file, as it is an output that >>it<< creates.
Put an entry into .ESEG
If this is an assembler exercise, explain the reference to "VMLAB compile".
I'm using what ever assembler VMLAB uses automatically. I have WinAVR installed with GCC too.
I've been clicking on the build icon. Then getting a compilation not complete eep file missing message. Here's what I'm using:
; BASIC .ASM template file for AVR
.include "C:\VMLAB\include\Tn22def.inc"
; Define here the variables
.def	I			=r16
.def	J			=r17
.def  K			=r18
.def  ONE		=r19
.def  LIM		=r20
.ESEG
eevar:	.DW	0xFF
.CSEG
; Define here Reset and interrupt vectors, if any
reset:
   rjmp start
   reti      ; Addr $01
   reti      ; Addr $02
   reti      ; Addr $03
   reti      ; Addr $04
   reti      ; Addr $05
   reti      ; Addr $06        Use 'rjmp myVector'
   reti      ; Addr $07        to define a interrupt vector
   reti      ; Addr $08
   reti      ; Addr $09
   reti      ; Addr $0A
   reti      ; Addr $0B        This is just an example
   reti      ; Addr $0C        Not all MCUs have the same
   reti      ; Addr $0D        number of interrupt vectors
   reti      ; Addr $0E
   reti      ; Addr $0F
   reti      ; Addr $10
; Program starts here after Reset
start:
   LDI I, 		0x00	; Initialize counter I to zero
   LDI J, 		0x00	; Initialize counter J to zero
   LDI K, 		0x00  ; Initialize counter K to zero
   LDI ONE, 	0x01  ; Initialize increment to 1
   LDI LIM, 	0x03  ; Initialize limit to 255
start_1:
	CP I, LIM
	BRLO end_1
	ADD I, ONE
start_2:
	CP J, LIM
	BRLO end_2
	ADD J, ONE
start_3:
	CP K, LIM
	BRLO end_3
	ADD K, ONE
	RJMP start_3
end_3:
	RJMP start_2
end_2:
	RJMP start_1
end_1:
Whoops, I just caught that the branches should be on equal rather than on lo. :)
Oh, and the ADDs could be INCs, then I could get rid of the ONE register.
The last time I coded assember, computers were the size of refrigerators and large freezers, IBM 360s etc.
The ESEG statement seems to have resulted in the creation of the *.eep file.
Although the build is still not complete for some un-reported reason.
Building process not completed!
Is all it says without any exclaimation marks in the build window.
Here's a screen shot of the message window.
It says the project file is OK, and code has no errs inside the window, but that the code is not OK at the bottom.
...but it says test6.hex is up to date, so maybe that's why it says the build did not complete.
Try deleting test6.hex and then rebuilding
Same thing happens.
I found it.
I put a RJMP at the end back to start. It cold just as well be to end_3, since I only want this to run once.
Apparent VMLAB want to insure continuous operation.
I'll be happy when I get past these initial blunders. :)
It's nifty how VMLAM refuses to let the program dead end. This runs as expected. Even without the ESEG statements it works.
.def	I			=r16
.def	J			=r17
.def  K			=r18
.def  LIM		=r19
.def	ZERO		=r20
.ESEG
eevar:	.DW	0xFFFF
.CSEG
reset:
   rjmp start
   reti      ; Addr $01
   reti      ; Addr $02
   reti      ; Addr $03
   reti      ; Addr $04
   reti      ; Addr $05
   reti      ; Addr $08
   reti      ; Addr $09
   reti      ; Addr $0A
   reti      ; Addr $0E
   reti      ; Addr $0F
   reti      ; Addr $10
start:
   LDI LIM, 	0xFF  ; Initialize limit
   LDI ZERO,	0X00	; Initialize re-initialization
start_1:
	CP I, LIM
	BREQ end_1
	INC I
start_2:
	CP J, LIM
	BREQ end_2
	INC J
start_3:
	CP K, LIM
	BREQ end_3
	INC K
	RJMP start_3
end_3:
	MOV K, ZERO
	RJMP start_2
end_2:
	MOV J, ZERO
	RJMP start_1
end_1:
	MOV I, ZERO
	RJMP start_1
