PORTC of ATMEGA324P acting funny
4 posts / 0 new
Trying to hook up 4 Seven Segment Displays to my ATMEGA324P.
PD0-PD3 passes power to the common anode of each digit one at a time. As each digit is powered, each segment has its current sunk into PC0-PC7 (also one at a time).
All of the displays have been tested.
I've checked continuity from the cathodes to their respective pins on PORTC.
Either PC2-PC5 are busted (they won't sink current for me), or there's a mistake in my code.
#include
#include
int main (void){
	DDRC = 0xFF; // set as output, sink current
	DDRD = 0x0F; // first 4 pins output, source current
	PORTC = 0x00;
	PORTD = 0x00;
	while(1){
		for (int j = 0; j < 8; j++){
			// set the segment pin low (sink)
			PORTC = ~(1<<j);
			for (int i = 0; i < 4; i++){
				PORTD |= (1<<i);
				_delay_ms(20);
				PORTD = 0x00;
This is the weirdest glitch I've ever encountered. Any input is greatly appreciated!
I know that the port groups on this micro can only source/sink 100mA simultaneously, but because I'm only lighting one segment at a time, I don't think this would be an issue.
You have the JTAG interface enabled?
You can change a fuse setting or write one to the JTD bit in MCUCSR at runtime.
I didn't enable JTAG, but I'll check the fuses
For convenience
Datasheet: http://www.atmel.com/dyn/resourc...
Pinout:
HAH! it works :)
Didn't know JTAG was enabled by default.
Thanks a million, Alan.
