[TUT] [SOFT] How to install JTAGICE mkII on Windows 7 x64
63 posts / 0 new
Hello to all Win7 users :D
I did not expect any problems while switching from Vista x64 to Win7 x64, but with the JTAGICE mkII I had some.
So here is a short step-by-step driver installation tutorial:
  1. As you may remember, there where always 2 devices in the Jungo-folder in the Device Manager. By right clicking on the computers name in the Device Manage, selecting "Add legacy hardware" you can install an extra driver.
  2. click next
  3. select "Install the hardware, that I manually select from a List (Advanced)"
  4. select "Show All Devices"
  5. click on "Have disc" and point to "C:\Program Files (x86)\Atmel\AVR Tools\usb64\windrvr6.inf"
  6. select WinDriver an continue by clicking "next" and "install" many times :wink:
  7. now you can install the JTAGICE mkII driver. Reinstall it, if you have tried it already, it should work now. If you let Windows search on the Internet, it will find the correct one.
  8. when it looks like this, it should work:
Tell me if there are some errors here...
Student at the University of Applied Sciences Ulm, Germany
Worked for my Dragon. Brilliant!
Thanks, worked great with my AVRISP mkII on Win7 64-bit as well!
you sir are the king of the internets :)
Two thumbs up from me as well. Worked perfectly for my Dragon.
Now I will try the same trick with the driver for my Xilinx FPGA dev board, which up until now has failed just like this one. Worth a try.
Thanks, did the trick with my avrisp mkII :)
works for stk600 as well! thanks!
You don't gno-me!
Thank you! I think my Dragon might work now. :)
Thanks a lot,
your methode works fine.
I use the AVRISP mkII with Windows7 64bit
best regards from germany
klaly
Spectacular! My ISP mkII now works with Win7 32bit; I was just about to throw it in the back of a drawer...
Many thanks.
I just want to add that it is critical to use the "Add legacy hardware"! I had previously installed Windows 7 64bit on my laptop and got everything working thanks to this guide. When I finally decided to upgrade my main system to Windows 7 64bit, the avrisp mkii was already in the device manager as an unknown device, so I simply updated the driver and pointed it to the correct driver.
It appeared to install correctly and the USB LED lite up like it should when I plugged in my avrisp mk ii. But, when I went to connect to it via AVR Studio, it could never connect and would time out and go back to the connection screen.
After playing with a a bit, I FINALLY remembered the "Add legacy hardware" bit and uninstalled the device, then reinstalled it correctly. Needless to say, it worked perfectly the first time when I installed it via the legacy hardware method.
Just something to keep in mind.
Clint
THANKS! dragon working on win 7 64bit
Thanks! This worked great for my mkII. Looks like I learned something new about Win7 :)
This forum is great for stuff like this!
-Justin
Yay ! It worketh again ! Thank you for the clear and detailed guide.
This do not work for me. Step 1-6 works (I get winDriver installed) but then how do I install the JTAGICE mkII driver ? I reinstall Avr studio 4 but that doesen't work it can't find the driver. Any ides? Can you download the JTAGICE mkII driver?
As far as I remember, I just let Windows search automatically for the Driver and that's all. But maybe you will find it at the same place as step 5.
EDIT: Step5 is not the correct answer. I can't say where to find it.
But as I said, Win7 will find it by itself.
Just to note that it's been reported that Studio 4.18 RC3 has been reported to work with without needing this mod. Future readers of this thread may well be reading this after the official release of Studio 4.18 so maybe try upgrading to that first?
So i have a problem.... my avrisp mkII doesnt work because the drive message is Device couldnt start (CODE 10) so whats the problem and how can i solve it?
i have the Windows 7 32-bit OS
Thanks for all useful answers
success! thank you... using AVRISP mkII with Win 7 x64
Wow, thanks so much! I got tired of haveing to switch to my XP laptop just to use the jtagice.
Many thanks.
I have new computer with Windows7 32 bit and installed AVRstudio version4.18 Build 692. Unfortunately AVRISP mkII and AVRATJTAGICE_MKII do not work (not able to connect), despite trying everything as per steps above. Any advice?
Everything works on the old WindowsXP machine.
Jan
I got same problem like this. Any idea?
KISS - Keep It Simple Stupid!
No sorry, this works fine for me. Maybe you deinstall your Jungo devices and start again?
With the newest drivers it should work also without my tutorial.
Thank you very much for yout hints! I needd it for the MK2 and AVR Studio32 2.5!
Thanks!!!
FYI, thanks as well.
BTW, Build 700 SP2 does not automatically find driver, at least not after a couple of minutes.
Just Want to add my thanks, they can never be enough for so much help
Ok, I realize that this thread has been dead for a while now but has anybody found a solution to this? I'm facing the same problem...
Have you tried SP3?
www.atmel.no/beta_ware/
clawson wrote:
Have you tried SP3?
Hey clawson, just downloaded SP3. Will give it a shot and let you know. I've tried downloading the latest driver pack from Jungo but that too hasn't helped. Have tried legacy mode installation aswell.
What i haven't tried yet is installing Avr Studio after logging in as Admin. Will that help? Studio is working fine, it's just the drivers for ISPmkII that are the problem right? well, will update later...
update:
Downloaded fresh packages of 4.18 + SP1+SP2+SP3+avr tool chain for SP3.
Installed everthing from the Admin account.
Ran the installation in compatibility mode.
Still doesn't work guys.
I get this from AVRStudio help:
    AVR Studio 4.18.715 GUI Version 4, 18, 0, 685
    Operating System
    Major 5
    Minor 1
    PlatformID 2
    Build 2600
    Service Pack 3
    Plugins:
    VDMAvrGUI
    AvrPluginAvrAsmObject 1, 0, 0, 48
    AvrPluginavrgccplugin 1, 0, 0, 11
    Stk500Dll 1, 0, 1, 15
Any suggestions? As i see it, i've two options left.
Running XP on a VM provided by microsoft OR simply running XP.
Once again, any kinda help would be appreciated. To sum it up, My device manager shows AVRISP mkII with an error code 10, (i.e. Device cannot start.)
Jungo Driver version 10.1.1.0
not to be dramatic or anything but HELP!!!!
UPDATE:
Installed Windows XP as a virtual machine using the software provided by microsoft but I still get the same error code.
I plugged in the ISP MKII into another PC that has Windows XP, works like without a hitch.
Any ideas??
Don't know if it helps but after installing avr32 studio 2.5, gnu toolchain 2.4.2 on windows 7 everything worked just fine for me.
The toolchain sorted out all windrivers without any effort on my part...
They have obviously applied the same technology as in SP3 for 8-bit AVR Studio which also seems to fix the Win7 situation too.
Ah well, worth a try. It would seem SP3 didn't sort out nightwarrior's problem.
thanks a lot for this post, and im glad i just found it.
The strange thing is, i just had issues getting my avr dragon to be recognized on my win7/64 notebook.
but, it used to work in the past. i used to flash some old mega88 prototype circuits a few months ago on the same machine/os.
now i couldnt connect to the drgon anymore. it showed up properly when being plugged in (both, windriver and avr dragon under device manager) but neither the upgrade nor the programming interface in avr studio found it.
after finding your thread i manually removed both drivers, installed the windriver manually by pointing to it and let windows look for updated avr dragon drivers.
after that, everything worked flawlessly again, updated the dragon and the programmer UI now loads up again.
i have no idea why it stopped working and required a manual removal/reinstall of the driver, tho...
Worked perfectly the first time. Instructions were dead on.
Kindest
I have W7 32 and running 4.18 build 700. It certainly still doesn't automatically install the drivers properly, and neither do the instructions at the top work exactly. Having done the manual legacy install, and deleted the existing driver it still doesn't automatically install properly when replugging my dragon. I have to go to "update driver software" on the faulty avrdragon device and select the .inf driver file (the same one as when doing the legacy install) manually. This then results in two Windriver devices in the Jungo folder and all finally works!
Hopefully that might be helpful for others still struggling - though given W7 has been out in the wild for a good 12 months, I do have to wonder how long it will take for Atmel to pull their finger out and fix this issue properly :? I guess more of us need to report it as a problem rather than simply fix it ourselves?
Thanks for the help. Win 7, 32-bit.
There is always a "simple" solution for a "complex" problem.
i'm looking at ur post, but i cann't see the pics of what you did. would be good if i can see them to make sure if i'm doing the right thing!
i hope you can post them i again!!
thanks!
What are you talking about? There aren't and never were any pictures accompanying this article.
Moderator
Sure there was. The three dead links are still present in the first post (on page 1). At least I see three small boxes with a red X in them.
Apologies - this browser was not showing image placeholders but when I edit the first post I see the URLs - try a PM to the OP which may trigger an email to his email account.
I'm sorry, must have deleted them from my webspace. I can't find a backup.
Edit: Found the Files.
Just pluged in my JtagIce2 with the new Studio5 beta, After a quick firmware upgrade it pushed in, away it went... did not see ant problems..
win7 64bit
Thanks for the detailed information. It worked with IAR in win 7. :)
Aaah getting mad :( Used AVR studio 4 with SP3 and AVR studio 5 on all three installations.
My AVR ISP MKII is having a code 28 error (does not install), on my Mac via Parallels windows XP and windows 7.
But ALSO on a windows 7 x64 pc, with Jungo 10.2 betafirmware, add legacy trick. EVERYTHING.
I can see the windriver in "device manager", just not the fact that my AVR ISP MKII is installed. I can see the programmer but it is a "unkown USB-Serial port device", with code 28.
You guys have any clue? The only option I see at the moment is getting a Windows XP computer and try again... The only one I can get my hands on has 128MB of ram :(
EDIT: Tried it now on a XP computer, with AVR studio 4 and AVR SP3. Still it does not work. The LED is green so nothing is wrong there, but the computer just cannot install the programmer.
What else can there be wrong?
I've tried everything
but does not work
I'll be mad
oh no, it doesn't work on my Windows 7, 64bit system. I can follow to step 5. After select the "WinDriver" in Step 6 nothing happens, so I can't click on "next" or continue. Any advices?
but does not work
I'll be mad
Your pictures show Jungo and LibUSB-Win32 for the USBTiny. It is one or the other, they both can't be installed at the same time.
Atmel makes the bad assumption that no other product in the universe uses the LibUSB-Win32 drivers. :-(
I was wondering if I could get a copy of the file in \Atmel\AVR Tools\USB 64?
I can't seem to get my ISP to work with the drivers contained in Studio 5.
Thanks.
Dimitri
how about win 8x 64? I tried this method but it doen't work with my computer
You don't need this tutorial with the current software from Atmel, they fixed this long ago.
I have no problems using JTAGCIEmk2, JTAGICEmk3 and AVRISPmk2 under Win7x64 without using my tutorial.
And I think they didn't change the driver model on Win8 (except printers or so), so I don't know whats wrong on your system.
Jungo
|--windriver (found)
Thanls a lot! Works great with JTAGICE mkII on my Win7 64bit
It is bit strange but making me crazy. Can you tell me what I have to to so install the JTAGICE MKII. I have followed the above process and got the success on one PC but it is not working on other PC; all things are same SW/HW. Can you tell me the way out to it?
Thanks in advance
in windows 8  you're not supposed to have problems for drivers signature,  in win 8.1  you will have to bypass the signature drivers ...  i use the latest atmel drivers v7 xxx on their web site.
The mkII needs to be listed under Jungo driver in devices ... no exclamation marks.
I am out in the field today attempting to install studio4.18 onto the junk windows 8 laptop.  Studio 4 ran but will not connect to the JTAGICE MKII.  Followed the instructions in this thread and I see the Jungo drivers with !  when I click on the update software it says "The hash file is not present in the specific catalog file. The file is likely corrupt or the victim of tampering"  "If you know the manufacture of your device you can visit the website and check the selection for driver software"
This was a fresh download of the 4.18 installer and the SP3 installer direct from Atmels website (I did not download and install SP1 and SP2)
any ideas?  It would be really nice if this computer could run studio 4.18  it sits in a drawer collecting dust.   I may update it to WIN 10, but would need to take it to a faster network.  It  really needs to run off the grid though.
Maybe the Jungo version; here's AVR Studio 4.19 on Windows 10 :
Where to download Jungo driver 11.5?
https://www.avrfreaks.net/forum/where-download-jungo-driver-115
Consider 8.1 as an interim.
Can take Windows 10 "off grid" though will need some thought (multiple ways).
Shield
IT Support Blog
Windows 8 End of Life – Upgrade Now!
by Eric Rostetter (Senior System Administrator)
February 1, 2016
https://sites.cns.utexas.edu/oit-blog/blog/windows-8-end-life-%E2%80%93-upgrade-now
The January 12, 2016 Patch Tuesday contained the last updates for Windows 8.
... Windows 8.1 is considered a service pack to Windows 8, and Microsoft provides two years to upgrade to a service pack before discontinuing support for the previous release.
Microsoft
Microsoft Support Lifecycle
Windows 8.1
https://support.microsoft.com/en-us/lifecycle?p1=13615#Microsoft-Windows-81
(that didn't work)
7. What is the Microsoft Support Lifecycle policy for Windows 8.1?
Windows 8.1 falls under the same lifecycle policy as Windows 8, and will reach end of Mainstream Support on January 9, 2018, and end of Extended Support on January 10, 2023. With the General Availability of Windows 8.1, customers on Windows 8 have 2 years, until January 12, 2016, to move to Windows 8.1 in order to remain supported.
Thanks for the pointers to the other threads.  I uninstalled everything including studio6.2, and the broken Jungo drivers, then reinstalled Studio4.18 and all 3 service packs.  For good measure I also installed the USB drivers from your link above.  I rebooted after the uninstall and after the re installs before connecting the JTAGICE MKII.  This time the JTAGICE MKII shows correctly in the device profile, and I was able to connect to it through the tools menu.
If I do upgrade the machine, it will be to windows 10.  There was a link here in one of the other threads to a standalone ISO installer.  Question is how unhappy is 10, when it is out of range of the network?
Windows Update would still be functional but via a Windows update server, supplied updates via mass storage, or peer-to-peer (an updated Windows 10 machine re-enters the group).
Windows telemetry is buffered into files :
Forbes
Microsoft Monday: Data That Windows 10 Collects, 'Free' Windows 10 Shows Ads, Android App Port Nixed
Feb 29, 2016 @ 05:00 PM
by Amit Chowdhry
http://www.forbes.com/sites/amitchowdhry/2016/02/29/microsoft-monday-data-that-windows-10-collects-free-windows-10-shows-ads-android-app-port-nixed/#54c837b0241b
Windows 10: What Does It Collect?
There are four types of Universal Telemetry Clients (UTC) on Windows 10: ...
The Windows 10 telemetry data is stored locally in encrypted files within the %ProgramData%MicrosoftDiagnosis folder.
... it is possible for Microsoft to collect personal or business information, especially at higher telemetry settings.
P.S.
Is your data your data?
Forbes
Microsoft Upgrades Windows 10 Powers Of Control [Updated]
by Gordon Kelly
Feb 11, 2016 @ 06:30 AM
http://www.forbes.com/sites/gordonkelly/2016/02/11/microsoft-makes-windows-10-u-turn/#266618243974
Update 15/02/2016: ...
... many users who are still adjusting to Windows 10’s vise-like control over updates which comes as part of Microsoft’s pledge to move Windows to a SaaS (software as a service) model.
... for now full control over telemetry is currently only being brought to Windows 10 Enterprise.
This means users of Windows 10 Home and Pro, typically consumers and small businesses respectively, will still need to cede control.
Whether you like it or not, Microsoft spells this out in the Windows 10 EULA – its house, its rules.
I have to run the IAR IDE (6.7) for company standards. The computer is running Win7x64 for the same reason. I installed Atmel Studio 7, and it works fine with the Atmel ICE MKII debugger. However, with the IAR IDE, it says it cannot find the device or it's already in use, even though I just rebooted and nothing else is running.
Suggestions?
Bruce
casner wrote:
Suggestions?
AS7 also installs new USB drivers which are no longer compatible with "old tools" and it looks like that means IAR too. So suggest you try to get the installation pack for the USB drivers in Studio 6.2 or below.
I have problem in installing JTAG ICE. At first the system had digital signature problem, so I disabled it then I try again, but I received error code (31) and it could not install.
could you please help me?
