Hi guys,
hoping to enjoy you all, I post here a simple and fast demo for Xplain that play 4 sec of a Luciano Pavarotti song.
I've one question: AvrGCC limit my array Music at about 28K or a little bit more. Why I can't use an array bigger example 115K?
If you want to try, I posted also an array bigger that is into the file PAVAROTTI.wa2 this is about 115K
The array that now I'm using and runs well, called "Music" is into the file Audio.h
You can try to use the array Music into the file PAVAROTTI.wa2 and delate the array Music into the Audio.h
For now the demo runs but play only 4 sec of music.
Using the PAVAROTTI.wa2 you could listen about 19 second of music but the compiler say that the array it's too large.
Is there a solution?
For now enjoy the demo. and I thank you if you have an answer at my question.
Bye.
Davide
