I'm doing a state machine to receive commands from the UASRT and this one case (code below) isn't working. Inspecting the lss output, it seems that GCC is optimizing out the buffer[Counter] = uart_tmp (check the output list after the code).
If I make buffer a global variable, GCC generates correct code. It doesn't need to be global, as it is only used inside the State_Machine function.
Any clues as why it is behaving like this?
Btw, I'm using WinAVR20100110 (dowloaded after 20/01/2010) and a m168 @ 18.432MHz.
void State_Machine (void) { uint8_t uart_tmp; char buffer[33]; // 32 bytes + \0 ... case SM_VFD_STR: uart_tmp = uart_getc(); if (uart_tmp != 0x0D) // 0x0D = Enter { buffer[Counter] = uart_tmp; Counter++; if (Counter > 32) { CurState = SM_ERROR; TipoErro = VFD_ERROR_STR; } } else { buffer[Counter] = 0; uart_puts(buffer); vfd_setstring(buffer); CurState = SM_END; } break; ...
case SM_VFD_STR: uart_tmp = uart_getc(); 8f2: 9e dc rcall .-1732 ; 0x2308f4: 90 91 5e 01 lds r25, 0x015E if (uart_tmp != 0x0D) // 0x0D = Enter 8f8: 8d 30 cpi r24, 0x0D ; 13 8fa: 69 f0 breq .+26 ; 0x916 <__stack+0x417> { buffer[Counter] = uart_tmp; // <-- it's not generating code! Counter++; 8fc: 89 2f mov r24, r25 8fe: 8f 5f subi r24, 0xFF ; 255 900: 80 93 5e 01 sts 0x015E, r24 if (Counter > 32) 904: 81 32 cpi r24, 0x21 ; 33 906: 20 f1 brcs .+72 ; 0x950 <__stack+0x451> { CurState = SM_ERROR; 908: 80 e1 ldi r24, 0x10 ; 16 90a: 80 93 40 01 sts 0x0140, r24 TipoErro = VFD_ERROR_STR; 90e: 89 e0 ldi r24, 0x09 ; 9 910: 80 93 5f 01 sts 0x015F, r24 914: 1d c0 rjmp .+58 ; 0x950 <__stack+0x451> } }
