Xmega ADC again questions
4 posts / 0 new
Hi, sorry if I post again a question about the XMEGA ADC but I need help.
I'm using an ATXMEGA256A3 REV_ID N° 0001.
Someone know from what rev_id the ADC problems are resolved?
I've strange problems, if I use the ADC in single ended the errors are very big 16-20 LSB.
If I use differential mode decrease at 4-6 LSB but I've an other problem....
I set the ADC like this:
ADC_CalibrationValues_Load(&ADCB);
ADC_ConvMode_and_Resolution_Config(&ADCB,
ADC_ConvMode_Signed,
ADC_RESOLUTION_12BIT_gc);
ADC_Prescaler_Config(&ADCB, ADC_PRESCALER_DIV512_gc);
ADC_Reference_Config(&ADCB,ADC_REFSEL_VCC_gc);
ADC_Ch_InputMode_and_Gain_Config(&ADCB.CH0,
ADC_CH_INPUTMODE_DIFFWGAIN_gc,
ADC_DRIVER_CH_GAIN_NONE);
ADC_Ch_InputMode_and_Gain_Config(&ADCB.CH1,
ADC_Ch_InputMux_Config(&ADCB.CH0,
DC_CH_MUXPOS_PIN4_gc,
ADC_CH_MUXNEG_PIN5_gc);
ADC_Ch_InputMux_Config(&ADCB.CH1,
ADC_CH_MUXPOS_PIN6_gc,
ADC_CH_MUXNEG_PIN7_gc);
ADC_SweepChannels_Config(&ADCB, ADC_SWEEP_0123_gc);
ADC_Enable(&ADCB);
ADC_Wait_32MHz(&ADCB);
ADC_FreeRunning_Enable(&ADCB);
I've two trimmers one on PB4 and one on PB6.
If I set trimmer1 and trimmer2 to 0V I rea 0001(decimal) on both channels.
If I increase trimmer1 to read 0455 (decimal) or some other value, on CH0, it increase a little bit also CH1 and I read ( CH0=0455 and CH1=0015) ?
How it's possible?
Where I can read the history of the REV_ID for to know if my microcontroller have a good ADC and I'm wrong or if it has bug?
Thanks.
Davide
You did read the Errata in the latest datasheet for the ATxmega256A3, didn't you?
Your Rev_ID indicates you have a Rev B chip (latest and greatest). According to the Errata, the ADC is limited to a reference voltage of 2.4 Volts. Not really knowing the real details of the circuit driving the input to the ADC, I cannot say more.
I will say that we use the ADC on a 128A1 (it has the same limitations) and have had no LSB issues with it, once we took the limited input voltage into account.
Stu
you are aware that, in single ended mode, the value is around 200 decimal when the input voltage is 0V, right?
Hi and thanks for your answers.
I read the errata but I did not understand if REVB was the version with the defects listed or were resolved defects listed. Unfortunately my English is not special and do not understand everything I read at 100% :)
Yes, in single ended I've an offset but not 200 it's about 140. The strange things is that in differential mode, if I increase the value on CH0 it increase a little bit also the value on CH1.(?) Now I'll try to use CH0 and CH2 for to see if something change. Thanks again.
Davide
