AVR GCC + Optimization + AVR Simulator = Fail.
7 posts / 0 new
I've been writing some code for some hardware I don't have in my possession at the moment. So I can't actually test the hardware at the moment.
I've been writing a general purpose SMBus driver.. So far I've got master transmitter/master receiver covered. I've got to then include ST/SR modes and handle arbitrations (multi-master bus)..
Anyways, I've been compiling on -02 and despite the fact the simulator doesn't do the TWI hardware I've fixed several bugs by modifying TW_STATUS directly in the simulator.
Next thing I change one small change and all hell breaks loose.
case TW_MT_SLA_ACK:							//SLA+W sent, ACK rcvd
		case TW_MT_DATA_ACK:						//Data sent, ACK rcvd
			//If there is data to be written out in MT mode
			if (writeIndex < twig.writeLen)
				//Update CRC value
				crc = pgm_read_byte_near(&(CRC8_CCITT_TABLE[crc^twig.txData[writeIndex]]));
				//Load byte into TWI Data Register, increment writeIndex
				TWDR = twig.txData[writeIndex++];
				//Configure TWI control register to signal ISR
				//when next event occurs
				TWI_Continue();
			Otherwise we have finished sending application-provided
			data. Insert PEC if necessary and stop transmission or
			change modes (i.e. write then read)
			//If the structure of this command is write-only
			else if ((twig.flags & TWIFL_WRITEONLY))
				//If PEC is enabled
				if ((twig.flags & TWIFL_USEPEC) && (writeIndex == twig.writeLen))
					//Load PEC into TWI Data Register
					TWDR = crc;
					//Increment writeIndex to prevent PEC being
					//sent over and over.
					writeIndex++;
					TWI_Continue();
					#warning "This will send PEC over & over"
					#warning "must fix"
				//Otherwise, PEC disabled. Stop and signal success
So, if the simulator/compiler were working correctly toghether (as they do if optimizations are turned off). Then under normal circumstances the first if statement:
would execute the statements within its scope and then execution would pass beyond the if/if-else/else block to the end of the case {} statement and would be broken out (break;) to the end of the ISR.
This all works as expected as long as the line 'writeIndex++;' is removed from the else-if block.
What happens when writeIndex++ is present in (-02)?
As execution enters if (writeIndex < twig.writeLen)
the statements within it are executed.. As execution leaves this block it should jump to the end of the ISR via the break; statement at the end of the case {}.
Instead, it jumps to the beginning statement of the else-if below it, starting at:
TWDR = crc;
Does anyone know if this is a simulator-only issue or if this bug is likely to occur on hardware as well? Also, does anyone know how to avoid this kind of behavior (even though it's clearly a bug)..
etc.. etc.. Any help/tips/thoughts you guys may have for me would be appreciated.
Thanks. Brad.
did you declare the writeIndex as volatile?
From the tread i make-up that you try to increse it inside the ISR.... then it must be volatile. otherwise a local copy is used inside the isr that is discarted after exiting the ISR, thus effectively never incresing your variable at all....
It's static within the ISR.
i.e. static uint8_t writeIndex = 0;
If it is static in the ISR(), then nothing else in the world can see it.
i.e. the 'writeIndex' in your foreground code is a completely different variable.
'static' restricts the scope to the module or block it is defined in.
'volatile' indicates that a variable may change value outside of program control. e.g. a loose cannon.
I'm aware.
writeIndex is used only within the ISR. It's not volatile global because I never need to use it outside the ISR.
I do have a struct of globals that are used to setup the TWI state, this struct is declared as a volatile, i.e.
volatile TWI_GLOBALS twit;
Have you verified this from the disassembly? Debuggers and simulators often have a really hard time mapping the execution to source rows when optimizations are on.
I haven't jumped into verification at the assembly level.
Fortunately, I was able to make a small change in the code to get a more predictable sequence of events in the simulator (unless I was making a mistake, it appeared the code wasn't executing as written before).
I just swapped the lines TWDR=crc;/writeIndex++, i.e.
					writeIndex++;
					TWDR = crc;
The code then executes as expected (though there are places where code that does exactly the same thing is reused, i.e. the simulator jumps to a non-linear point in a linear sequence). Does that make sense? Basically, code that does exactly the same thing & has the same exit point is reused, which is fine.
As the code matures to support multi-master & slave operation I'll try to diassemble it.
