semicolon after a brace in AVR-GCC-> when?
18 posts / 0 new
what is the meaning of semicolons after closing braces?
First, do what you can - then, do what's possible - suddenly, you'll do the impossible. (Thadëus Judas )
Example?
Leon Heller G1HSM
semicolons are used to terminate a command, braces are used to enclose a section of code (eg to mark the boundary of code that's inside an 'if' statement).
I have never used a semicolon after a closing brace when coding AVR-GCC.
Never? Never initialized an array or a structure?
Standard C allows "empty" commands, so you can even place consecutive semikolons, and of course even after closing braces. They are just omitted.
/Martin.
Also at the end of an enum definition.
in AVR-GCC
These things are dictated by the C standard, not avr-gcc. All implementations of C will be the same.
Steve A.
Not always
if(PINB==0)
   PORTC=1;
   PORTA=2;
};          //error
   PORTC=0;
if(PINB==0)
   PORTC=1;
   PORTA=2;
};          //this semikolon terminates the if-statement
else        //else without if is an invalid statement
   PORTC=0;
/Martin.
I explain it to myself this way
if(PINB==0)
   PORTC=1;
   PORTA=2;
...    //here may not be any command, neither empty one
   PORTC=0;
Question of style, I prefer to format the code like this:
if (PINB==0) {
    PORTC=1;
} else {
    PORTA=1;
For me the curly braces and the if/else/while etc. statements belong together.
Markus
Me too - always wrap even single if(){} or else{} statements in braces or you can face the classic error:
if(PINB==0)
   PORTC=1;
   PORTA=2;
   PORTC=0;
becoming, after a small modification:
if(PINB==0)
   PORTC=1;
   PORTA=2;
   PORTC=0;
   PORTA=0;
which is almost certainly not what the programmer intended!
BTW this thread has nothing to do about GCC specifically - it's a question about ISO ANSI C so I won't move this thread to the GCC forum. (just in case anyone thought the mention of "avr-gcc" in the thread title meant it should move ;-))
Same here. When I was working, we were required to have a coding standards document for each project. I always specified this as a required coding standard.
Don
Fair enough for statically initialising an array. I have done it in the past, but so long ago it didn't come to mind :)
structures though, use this syntax:
typedef struct
	char data[DATA_BYTES];
	char CRC[CRC_BYTES];
} MessagePayload;
is there an alternate syntax that compiles?
re if/else statements I agree that proper coding standard is to always include the braces to make it explicitly clear what the intended execution is.
No, typedef uses that format. For a struct alone it would be:
struct MessagePayload
Steve A.
Maybe the OP means something used like this:(from Dean's USART tutorial)
while ((UCSRA & (1 << RXC)) == 0) {}; // Do nothing until data have been recieved and is ready to be read from UDR
The semicolon in this case is used to tell the compiler that the "do nothing" (open braces) command is terminated.
But in that case, the semi-colon is redundant.
Steve A.
I always do explicit braces when there's an empty statement like
volatile BOOL haveInterrupt;
while ( !haveInterrupt )
just for clarity as compared to the more confusing
while (!haveInterrupt);
in whch case you have to look carefully to see the semicolon.
Some organizations (big) have coding style standards so everyone does it the same way out of sympathy for future code-readers in a team.
Visovian wrote:
Not always
if(PINB==0)
   PORTC=1;
   PORTA=2;
};          //error
   PORTC=0;
even 'better':
if (PINA == 0)
    if (PINB == 0)
        PORTC = 1;
        PORTA = 2;
    };             // not a syntax error
        PORTC = 0; // muwahahahaha
