Setting vars in ISRs and the main loop
3 posts / 0 new
Hi all,
I have written a simple BIOS for my ATMEGA8 that uses
ISR(TIMER2_COMP_vect)
ISR(USART_RXC_vect)
The controlling Solaris application can communiate with the AVR over a serial line. A specific command starts some magic with timer 2 in CTC mode. At the end of this magic a global variable _state is reset to 0 thus signaling the main loop that the experiment is over and C is to be sent via the serial interface to signal end of the experiment to the controlling Solaris software. My main loop looks as follows:
while (1)                       /* loop forever */
          if (_notifyEndOfExperiment == 1 && _state == 0)
            _notifyEndOfExperiment = 0;
            TxByte('C');
            TxByte(0x0D);
I know that the main loop runs since inserting code like
TxByte('V');
delay_ms(1000);
gives me a V on the serial line every second. I can also check the state of the variables
static uint8_t _notifyEndOfExperiment;
static uint8_t _state;
by sending another command to the BIOS that executes
TxByte('c');
putInt_in_serial_trans_buffer((int)_state);
TxByte(',');
putInt_in_serial_trans_buffer((int)_notifyEndOfExperiment);
TxByte(0x0D);
This gives me c0,1 so I know the state of these variables is as it should be. Nevertheless the body of
            TxByte('C');
            TxByte(0x0D);
is never executed. I never see the C on the serial line. I am clueless. What am I missing? Any idea?
Thanks a lot!!
I presme these variables get altered by the ISR()'s. So declare volatile:
volatile static uint8_t _notifyEndOfExperiment;
volatile static uint8_t _state;
Yes, they are. And yes, replacing static with volatile did the trick.
Thanks so much!!!
