drive a solenoid with mega digital I/O
13 posts / 0 new
probably a simple one but i can't seem to find something obvious :?
Looking at a 24v AC solenoid to control water flow (sprinkler system) and want to control it from a MEGA's IO. Have no idea what to look at - opto couplers, relays, and 24vac power supplies......
From my research, i think i'll need a transistor (plus diode) to allow the mega to switch a relay, that switches the 24vac supply on/off as needed, thats connected to the solenoid. Anything else I'm missing?
thanks in advance
BP
Would depend also on how often you would have to turn it on/off, if it is very often a relay will soon wear out. How high current will it draw? If not too high a transistor and a diode might drive it directly.
The simplest method is as you describe. As for kherseth's comment about the relay wearing out, I don't think that would be a problem as a correctly sized relay will probably last over a million operations and your solenoid valve will probably have worn out by then.
The other option is a use triacs but that introduces a few problems of its own. You can't go too wrong with a relay.
You probably will want to use a relay driver to handle the relay coils current requirements. On Semi makes some little driver IC for less than 1$. They have the diode built in to protect the AVR from the back voltage of the relay coil. See NUD3112 for one example.
Relays may not be perfect for this.
Yes, you could use a transistor and diode to drive a relay coil with DC voltage, and control 24VAC with the relay, but depending on the load switching the relay on and off may wear out the contacts unless you design a snubber over the relay contact pins.
You could consider putting a opto-isolated triac there. To your AVR it would look like a LED. Examples are MOC3010 or similar.
Jepael, the moc3010 style devices are not specced to switch loads other than triacs - this is mentioned in the datasheet, so you would also need to add a triac.
some more info from me, and some more questions, of course...
i have no idea about the solenoid i've seen (which I only saw as I was strolling the aisles in Bunnings). I am guessing I need to find out it's curent draw (if i was to buy one) to figure out the relay sizing?
(edited for clarity) Duty cycle impact on relay life should be small. Initially i'd expect several switching events in a day, most likely only say 4 on/off event combos a day MAX. Nothing too stressful for a relay I'm guessing.
Kartman, any jaycar (or other AU based commodity component place) pointers/refs on relays?
Sorry. I just know there are some similar chips that can drive 230VAC loads directly, and I thought wrong.
Edit: Oh yes, solid-state relays could be for this?
Something like this:
http://www.jaycar.com.au/product...
rated for 5A so that should be more than enough.
Using a BC548 or similar transistor will drive the relay - use a 1k resistor in series to the base or use a ULN2003 chip and get 7 high current drivers in the one package.
You could also try Oatley Electronics, paying $6 at Jaycar seems a bit steep for me. You could also troll electronic junk places for boards with 12V relays on them.
if you are talking about 24V AC you should use a triac which can handle the solenoids current. Let the ATmegas I/O drive the gate and that's it. Reliable, noiseless and easy.
Duty cycle very often is limited by the power not by the number of usage.
Hey uC-Harry, do you have any references to triacs that would help me design that?
Just about any triac with the required current rating. In your instance this would be less than 1A. Something like a BT136 should be easy to get.
Without using any isolation, this means the 0V rail of your AVR and associated electronics becomes one of the 24VAC wires - this is something you need to consider carefully in regards to your power supply to the AVR. I suggested the relays since this gives you isolation and is quite easy however, commercial products would most likely use a triac due to cost.
it's a couple of years ago that I used a triac. But Kartman suggestion sounds good to me. I had a look into the datasheet and I think it will work. With TIC225D or better 2N6075B you will find one with a little bit more sensitive gate.
