NTSC composite video VSync
2 posts / 0 new
Hello everyone!
I am currently developing a small project that consists of generating NTSC composite signals for monochrome video with an atmega328P chip running at 14.7456MHz.
However, I have been having troubles understanding the Vertical Sync timing issues...
Here is my code:
int count = 0;
int main() {
DDRB |= (1<<PB3);
DDRB |= (1<<PB2);
//Horizontal sync
void sync ()
    PORTB &= ~(1<<PB3);
    PORTB &= ~(1<<PB2);
    _delay_us(4);
    count++;
//Vertical Sync
void Vsync ()
    PORTB &= ~(1<<PB3);
    PORTB &= ~(1<<PB2);
    _delay_us(192); //6 long syncs of 30us followed by a 2us sync
  while(1) {
//Will draw a gray bar at line 150 with a white background...
if( count != 150 )
           PORTB &= ~(1<<PB2);
        _delay_us(8);
        PORTB |= (1<<PB2);
        _delay_us(52);
           sync();
if( count == 150 )
    PORTB &= ~(1<<PB3);
    _delay_us(8);
    PORTB |= (1<<PB3);
    _delay_us(52);
    sync();
      if( count == 262 ) Vsync(); //Even VSync
      if( count == 525){ count = 1;     Vsync(); } //Odd VSync
  return 0;
I could draw a gray bar at the middle, but the screen is kinda flickering. The gray bar looks like "blinking". and there is a very flickering black part at the right border of the screen.
Am I generating a correct synchronization with the TV?
You are never going to get the required accuracy in C alone - it needs to be cycle accurate - use Asm for the key timing generation
EDIT oh great - this turns out to be a cross-post - locked:
Topic locked
