time from SPI TXEMPTY to RDRF?
5 posts / 0 new
hi,
I can't find any info about this time (or number of MCK clocks) between TXEMPTY flag set to RDRF flag set on UC3B's datasheet.
I need to know this because if the previous received data in RDR is not read out, then I think RDRF will be kept at set, so if then send out another byte and wait for the new received byte to replace the old data in RDR, then I guess the spi_read() function I used, could end up return me the previous data in RDR, not the new one (this is of course if the time between TXEMPTY to RDRF is quite long).
Anyone knows?
What about using an "blind" read before sending, then do the "real" read. You cannot read it too many times :)
well, yes, that's ok, but I want to know this timing first.
You should email atmel support about that.
Anyway, here is example of C procedure I use for UC3 slave:
unsigned int local_spi16(volatile avr32_spi_t *spi, unsigned short outdata) {
   unsigned short temp11;
   temp11 = spi->rdr >> AVR32_SPI_RDR_RD_OFFSET; // Clear RDRF
   spi->tdr = outdata << AVR32_SPI_TDR_TD_OFFSET;
   gpio_port_pa->ovrs  = 1 << (AVR32_PIN_PA09 & 0x1F); // Attend master
   while ((spi->sr & AVR32_SPI_SR_RDRF_MASK) != AVR32_SPI_SR_RDRF_MASK);
   gpio_port_pa->ovrc  = 1 << (AVR32_PIN_PA09 & 0x1F);		// Confirm to master
   return temp11;
SPI is difficult if the slave is not responding instantly at all times. The above example use a separate IO pin to acknowledge the SPI master.
ok, thanks, i will send them email.
