costs of volatile
11 posts / 0 new
Is there any memory or processing cost or downside to declaring a variable volatile?
There must be!
Of-course. No optimization is done on items being declared volatile. So "more" code will be generated and executed. Ie both memory cost and execution time cost.
You can see this yourself:
#include
int main(void) {
	uint8_t value = 0x5A;
	while(1) {
		PORTB = value;
generates:
0000006c
: int main(void) { uint8_t value = 0x5A; while(1) { PORTB = value; 6c: 8a e5 ldi r24, 0x5A ; 90 6e: 88 bb out 0x18, r24 ; 24 70: fe cf rjmp .-4 ; 0x6e
on the other hand:
int main(void) {
	volatile uint8_t value = 0x5A;
	while(1) {
		PORTB = value;
generates:
0000006c
: #include int main(void) { 6c: df 93 push r29 6e: cf 93 push r28 70: 0f 92 push r0 72: cd b7 in r28, 0x3d ; 61 74: de b7 in r29, 0x3e ; 62 volatile uint8_t value = 0x5A; 76: 8a e5 ldi r24, 0x5A ; 90 78: 89 83 std Y+1, r24 ; 0x01 while(1) { PORTB = value; 7a: 89 81 ldd r24, Y+1 ; 0x01 7c: 88 bb out 0x18, r24 ; 24 7e: fd cf rjmp .-6 ; 0x7a
Only use 'volatile' when you have to.
The question is so generic. "Have you stopped beating your wife yet? Answer yes or no."
Is there a "cost" to not using volatile, when needed? Yes; your program will not operate correctly.
Is there a "cost" to declaring everything volatile? In all probability yes; you will cripple the optimizer.
Can you minimize the "cost" with some thought? Yes. Consider the below:
volatile unsigned char frog;
for (i = 0; i < frog; i++)
.. do something useful
with
unsigned char dog;
dog = frog;
for (i = 0; i < dog; i++)
unsigned char dog;
dog = frog;
Of course, the whole purpose to declaring a variable volatile is to tell the compiler that "something" (usually either hardware or an ISR) can change the variable behind the compiler's back. So, in the code above, if frog changes while the processor is in the dog for loop, the loop will not see the change; the loop will continue to the value of frog immediately before the for loop was started.
Stu
Exactly, Stu. As implied by the example, the volatile variable is often from an ISR--ADC counts, ICP time, encoder counts. Often, the main loop acting on the information wants a snapshot and then go on and close the loop.
[But not always--it depends on >>your<< app!!]
The point is that in the simple loop above the volatile may cause an extra LDS each loop, and virtually doubles the loop overhead time. Continuing with the contrived example, perhaps frog is ADCH counts. And perhaps we toggle a pin to indicate that number. Say we start out with frog being 0x66 and we are using it directly as a volatile. Then when our i count is 0x44 it changes to 0x22. We have now acted on a value that is neither fish nor fowl.
It depends. OP's question cannot be answered yea or no and one size does not fit all.
Lee
dog = frog???
Are you people on drugs or something?
ROFL
It may (or may not) be worth noting that these volatile rules-of-thumb are somewhat GCC specific. I know we are in the GCC forum but some of the young'ens might be interested that other compilers may behave differently with regard to optimization and volatile.
C: i = "told you so";
John_A_Brown wrote:
dog = frog???
:lol: :lol:
I figured there would have to be... moral of the story: if you need to use volatile to get your program to work right, use it. otherwise don't.
More correctly, use volatile when it is required.
