Seeing crystall waveform with oscilloscope!
7 posts / 0 new
I recently bought a Agilent Oscilloscope and i wanted to see the crystal output on a AVR Board! The only thing i saw was a sinus-like waveform and the frequency i got was ~90MHz!!!
Shouldn't i see a square waveform of e.g. 8MHz (when i have a 8MHz crystal)?
I wanted to compare the UART outputs together with the clock rising/falling edge.
What was the amplitude of 90MHz sine?
Weird things can happen if you just poke something to crystal pins - but I would never have guessed 90MHz sine.
If your scope is not broken, use a 10x attennuating probe, and you set the timebase to something like 1us or 10us / div and voltage base to something like 1V or 100mV / div, you should see sine or square wave at the crystal frequency.
Whether it is sine or square depends on the AVR fuses, if the output is normal or full-swing.
Then again, you may see something random if the fuses are set to internal RC oscillator, so the crystal does not operate.
You should be able to see a reasonable waveform on XTAL2 using a X10 probe.
I cannot see the point of inspecting the UART outputs. If you program the AVR correctly, it just works.
Is the waveform clean and stable on the scope? In other words, is it triggered correctly on the scope? If you see a "jitter" in the waveform on the scope, it may not be triggered or stable in which case, the measured frequency will be wrong. Try changing the trigger level on the scope.
Which model of AVR? If it has a CKOUT fuse/pin set/monitor that and you'll see a nice, full-swing square wave at F_CPU.
Alternatively program the UART for a known baud rate then transmit 'U' repeatedly at 8N1. For example you should see 104us bits for 9600 baud if F_CPU is what you think it is (when programming UBRR)
Thanks to all.
I will be back at home in about 1hr. I will take some images from the scope in order to see the waveform!
I will check the fuses on will attach them to here..
Thanks a lot
-G
If you are doing this in order to base a design on the observed phase relationship - don't. Atmel specifically say that there is no guaranteed timing relationship between the oscillator and the edges of peripheral transitions.
Roger
