Programming without a clock
8 posts / 0 new
After some time trying to figure out why I couldn't program my AVR, I tried putting a crystal across XTAL1/2. Suddenly I could program it! I assume this indicates that an oscillator or clock source is needed while programming.
Let's say I don't have a crystal or any sort of means to generate a clock signal AND I have my fuse bytes set to something other than the internal clock... is there still a way to program the AVR?
This is purely out of curiosity.
Yes, depending on the AVR, JTAG and HVPP.
Thanks!
Here's a common trick that I learned here on AVR Freaks: You can hack a clock out of a serial line: program the serial line (say, from your PC) to send "U" constantly (8-N-1) at some nice baud rate. Convert the serial line to a logic level (through something as simple as a resistor divider network, or if you have an RS-232 converter on board, use it's output) and feed it to the clock line. Voila, you have a clock running at the baud rate (since ASCII U is binary 01010101).
Or, if you have a 555 timer hanging around, hack together a quick clock reference.
Clock sources are really simple to build. An oscillator and a huge-gain amplifier following usually does the trick. Heck, if you have a Hex Inverter chip, tie an odd number of inverters into a chain with some caps on each stage.
Stu
Quite true. I just put together an oscillator, to measure some bags of mystery crystals, out of one jfet (floor sweepings from a job I had in college - I keep everything!) and two resistors.
555s, an AVR toggling an output, some hex inverters, there are lots of ways to get a clock pulse. But I hadn't thought of the serial port as a clock source before.
I have a multimeter with a 4096Hz clock output. Good enough to restore fuses, nothing to build....not that I ever need it of course... :?
I wonder if you can connect to the o/p of a digital/analog watch to get the 32.768kHZ signal for a clock.
:lol: A Real Engineer(tm) would be able to do it assisted only by his trusty Swiss Army knife!
Even better, s/he will have figured out how a USB Digital Watch can be used to supply to clock directly and download to the AVR!
Stu
