USART Inverted Data on 128
5 posts / 0 new
I'm trying to talk to a SED1565 GLCD. Anyhoo... When I set up Synchronous Tx on a 128L everything is beautiful - signal comes on rising clock, etc. -- only one problemo: The data pin (TXD1) is *Hi*, and flips down to grnd and back up w/ signal. In looking at another chip (unknown; but was driving the SED1565 successfully) I see that it's data signal is at GROUND, and flips up to Vcc w/ signal. I don't see a setting for this in the UART regs... I understand that the way the 128's doing it may be corrct serial 'standard'.
I thought maybe the 128 has a register to "Invert pin" er something. (wishfull thinking - i know). I guess I could write an int on another pin which inverts whatever's on the Tx pin.. 'nuther thought was to use a different proto (like SPI 2W, etc.), as some of these look like they have polarity as settings...
Any ideas?
Robert
admin's test signature
I Think you'll be out of luck with this, most if not all UARTs/USARTs idle high at the logic level outputs. I've never come across any that idle low.
Having just looked at the Epson spec, you should be using the SPI module, not the synchronous USART. The USART sends bit 0 first, while the SPI sends bit 7 first.
Alternatively, if you're already using the SPI pins, you could always bit-bang, being a synchronous protocol the timing shouldn't be critical.
John,
Thanks for your response and suggestion - I'll try 'hooking-up' SPI today. Any warnings for this endeavor?
Thanks again,
Robert
No, I've only used graphics LCDs in parallel mode, but it all looks quite straightforward.
