ADC pin with pull up? detecting when nothing is connected
6 posts / 0 new
Hi All
My AVR voltage is 3.3V so this is my ref point.
I need to read voltage that range from 0V to 3V using the ADC
So 3.3V is never read.
But i would like to know is it possible with the ADC and without disturbing it performance to have either a internal or external pull up, so when 3.3V is read i can see it as that it's not connected to my sensor.
Regards
DJ
Regards
DJ
So you just turn on the internal pull-up, read the ADC and if you get > 3.0V you have no input.
When you are reading a real input, turn off any pull-ups so that you are not loading the input.
If you want to avoid additional switching...
(but more electrical solution)
Try to think in the other way:
Add an offset of 0.3V sensor-sided (it is only present if the sensor is connected)
To avoid floating of the pin add a pull down to the ADC pin.
If you're now measuring <0.3V your sensor isn't connected.
You just have to move your interpretation from 0-3V == 0..100% to 0.3-3.3V == 0..100%.
A SUCCESSFUL day to all of you! ;)
I have used an external pull up (just a simple resistor connected to the 5V supply) to connect to my ADC pin. When the ADC pin is floating, it reads 5V (after conversion in software) You can probably use the internal pull up but my app. required a variable pull up resistor.
I can give this a go. If i do now get a 3.3V, i can then switch off the pull up
Could you explain please?
Regards
DJ
@djoshi
What should I explain? Please be a bit more specific.
My solution will work too. The only problem you could have is, that sensor outputs normally are of low resistance. Therewith it isn't done to add the offset simply by using a potential divider because you should never load sensor outputs (..to heavy). You have really take care of impedance effects!
You havn't said how many additional instruction are "disturbing" to your solution.
So my solution is not easy and only worth doing if you have really no time in program flow for the additional instructions switiching the interenal pull-up and checks.
The principle is the same like sensors with current outputs have (4mA..20mA).
0mA => no sensor (often additional: 24mA => sensor broken for example)
It's a really common solution...you will find enough material (circuit diagrams...) through out the web.
I just wanted to give you a second solution... :)
