Problems with io.h
2 posts / 0 new
Having installed the latest AVR GCC and followed the instructions in the PDF , I keep getting a warning:
device type not defined
I have MCU=atmega16 in the makefile.
Then, the next time I try to make all, I get a message about a null characted being encountered in file test1
What is the file "test1" anyway?
If I delete it, I go back to the "device not defined" warning.
What is going on?
Many thanks for your reply, I think the makefile was incompatible with the latest WinAVR, I downloaded some other example code (avrgcc-examples.zip) which all behave.
BTW I did mean WinAVR 20030913 and "Installing and Configuring WinAVR"
John Brown
