How to identify the C compiler being used
9 posts / 0 new
[I hate to ask questions that must have been answered somewhere in the docs, but i searched the manuals without success...]
In order to easily simulate parts of my current project, i wrote a small simulator for my actual hardware in Dev-Cpp on the PC (Windows) to test my state machine code. The module containing the state machine is written in a portable way without any knowledge of the underlying hardware. Now, how can i detect the platform i'm compiling this module on? I mean there must be some definition of __AVRGCC__ or such, but so far i couldn't find any documentation about such defined words in the avr-gcc environment.
Can you tell me what definition to check for to tell that the module should be compiled for an AVR? And, could you post a reference to the relevant docs you found that info?
Thanks in advance,
-- Thilo
Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
__GNUC__
__CODEVISIONAVR__
__IAR_SYSTEMS_ICC__
__IMAGECRAFT__
__ROWLEY
You need to also detect the CPU model etc. Unfortunately this can get a little bloated: e.g.
#if defined(__AVR_ATxmega128A1__) || defined(_CHIP_ATXMEGA128A1_)
because all Compilers use a different system to identify the model.
But you should find the predefined macros advertised/hidden in the Compiler docs.
A lot of ways.
I have just used
#ifdef AVR
or
#ifdef WIN32
or similar. There is a command to see what preprocessor macros are defined. The AVR and WIN32 may be in the form of __AVR__ or __WIN32__, I don't remember any more.
Thanks to all for the answers, i gues Jepael's hint for testing "AVR" ist the one i was for. I can't use __GNUC__ since there are GNU C Compilers for Windows as well, and i need to determine the general hardware platform. I guess i could also just test if __AVR_ARCH__ is defined...
At the top of the link I posted (manual) it shows that avr-gcc defines AVR, __AVR, and __AVR__
Ah-ha. You did want to distinguish platforms and not just the Compiler.
#if defined(__GNUC__) && defined(AVR)
Likewise you have to test both Compiler and Target for IAR etc...
Not all AVR Compilers predefine 'AVR'. It is safer to use the __NAMES__ because they are more likely to reflect the particular Compiler.
Ok, i neglected to mention that i'm using avr-gcc/WinAVR for the 'real' stuff. But in order to distinguish the different platforms for a build run, it's simply not enough to check for GNUC, when your compiler on the PC side is also a GCC variant (and i mentioned Dev-Cpp in the base note). Therefore i really was looking for a way to distinguish the platform, not the compiler. And this has been addressed for avr-gcc/WinAVR pretty fine with the AVR/__AVR__ definitions.
Again thanks to all for the very useful comments!
-- Thilo
You could always do it yourself, e.g.
... -D__PLATFORM__=avr-gcc_on windows95 ...
"Demons after money.
Whatever happened to the still beating heart of a virgin?
No one has any standards anymore." -- Giles
