Spot welder triac control. Feasibility?
5 posts / 0 new
Hi Guys:
I'm making a homemade spot welder as a hobby project. I salvaged an old AC stabilizer and recovered the autotransformer. With that core I calculated that I can make a decent 2KW spot welder (well inside the light-medium duty commercial spot welders)
Now, my problem is that, for tiny metal sheets and/or wires I'd like to control the output current of the welder (to set to a max amount, not continous regulation).
I though first in a transformer with a tapped primary in order to reduce the "open" voltage and then control the max output current to some extent with a selector or relays.
Then I realized that make taps into a 2mm dia. wire is somewhat difficult (but not impossible) and let's the winding deformed (I need to attach a bar as secondary or a very big cable) so, begun to think what about a triac control.
I looked for spot welder schematics and there are none with triac control. May be a triac SWITCH (on off) but not control.
Is this impossible? or expensive ? Unreliable to fit in a commercial welder? the primary full current would be no more than 15A at overload (+-10A@220V at 2KW)
Does anyone here have built a spot welder? and tried to do such control?
thanks in advance
Nachus
You should be able to do what you want using phase control. I would suggest using an "Alternistor" instead of a common triac. These are made by Teccor/Littlefuse and hook up the same way as triacs, but they are a little more rugged and perform more like back-to-back scrs. I used to work on large resistance welding equipment and one style used Ignitrons to phase control a 400kw transformer so in theory, it should work for you.
Tom Pappano
Tulsa, Oklahoma
How do I get my AVR to fire a ignitron? Where do I buy them? Digikey doesn't have them listed.
(tongue planted firmly in cheek).
ST has to good triac with "snuber less" it is the same than "Alternistor"
or use a std triac 25A with a snubber.
Thierry
Thierry Pottier
Thanks Guys: I can get here in Argentina some "alternistors", more of the type Thierry says (The ST snubberless triacs) I'll try that, with microcontroller phase angle, and timing.
Thank you
Nachus
