OK, so here's my first attempt at reading the ADC from an attiny44 running on a 20MHz clock. I have a receiving ultrasonic transducer hooked up to the pin, but am not utilizing the transmitter at this time. Regardless, I think that I should be seeing a little noise on on pin 0 of the adc, but I am just getting solid 0's. Is my configuration correct?
Thanks!
#include#include #include #include #include #define txPin PA1 // transmit pin #define rxPin PA2 // receive pin #define outputSpeakerPinOne PA7 #define outputSpeakerPinTwo PB2 #define bitDelayTime 8.7 // bit delay, 1/115200 in usec at 20 MHZ #define bitDelay() _delay_us(bitDelayTime) // RS232 bit delay #define halfBitDelay() _delay_us(bitDelayTime/2) // RS232 half bit delay #define outputA(pin) (DDRA |= byte(pin)) // set PORTA pin for output #define outputB(pin) (DDRB |= byte(pin)) // set PORTB pin for output #define setA(pin) (PORTA |= byte(pin)) // set pin in PORTA #define clearA(pin) (PORTA &= ~(byte(pin))) // clear pin in PORTA #define setB(pin) (PORTB |= byte(pin)) // set pin in PORTB #define clearB(pin) (PORTB &= ~(byte(pin))) // clear pin in PORTB #define pinTestA(bit) (PINA & (1 << bit)) // test for pin in PORTA #define bitTest(byte,bit) (byte & (1 << bit)) // test for bit set #define byte(bit) (1 << bit) // byte with bit set volatile char rxbyte; ISR(ADC_vect) //ADC interrupt service routine { rxbyte = ADCH; } void putChar(char txchar) { txchar = txchar ^ 0xFF; // // print the character in txchar // // start bit // clearA(txPin); bitDelay(); // // unrolled loop to write data bits // if bitTest(txchar,0) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,1) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,2) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,3) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,4) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,5) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,6) clearA(txPin); else setA(txPin); bitDelay(); if bitTest(txchar,7) clearA(txPin); else setA(txPin); bitDelay(); // // stop bit // setA(txPin); bitDelay(); } int main(void) { // // set clock divider to /1 // CLKPR = (1 << CLKPCE); CLKPR = (0 << CLKPS3) | (0 << CLKPS2) | (0 << CLKPS1) | (0 << CLKPS0); //Initialize ADC ADMUX = _BV(REFS1); //Set internal 1.1 voltage as reference; default pin to read is 0 ADCSRA = _BV(ADEN) | _BV(ADSC) | _BV(ADIE) | _BV(ADPS2) | _BV(ADPS0); // Enable ADC. Start conversions. Enable conversion interrupt (remember to enable global interrupts). Prescaler set to /32 (running at 625 kHz). ADCSRB = _BV(ADLAR); //Left shift the results so that i can just read off the 8-bit value because I am running it fast // // initialize output pins // outputA(txPin); setA(txPin); // // main loop // sei(); //enable interrupts while (1) { putChar(rxbyte); _delay_ms(100); } }
