Data segment > 100%?
12 posts / 0 new
Is it a problem that I need to fix that the gcc compiler is reporting I'm at 130% of the data segment?
If so how do I fix it?
I'm using GCC (via winavr) in AVR Studio.
I hope this is an appropriate forum for this. I've searched for an hour but can't find anything that explains it. I hope someone can please point me in the right direction.
Yes, definitely.
How you fix it depends on what is using the memory. Without seeing your code it is hard to be sure, but one of the most common things that you can do is make sure that all of your constant strings are in flash, not ram (through the use of PROGMEM).
Steve A.
Thanks, that sounds like just what I need to do.
I do have an array of 400 bytes. This is on an ATtiny85V. I'll look into PROGMEM. Hopefully at the same time I'll find a solution to my other issue: An efficient way to define a large static array of bytes. I was searching for how to define array literals in C, and was surprised to find pages saying C++ does not support them. I'm using C, which I assume is the same in this way.
Thanks again!
Tim
Okay, it looks like I'm on my way. I found the progmem tuturial by abcminiuser and an example of array literals. Thanks again!
C++ does not support the use of literal arrays as initialisers for non-trivial objects.
No, it's not really. The C++ restriction arises out of the strictness with which C++ approaches object construction and initialisation. C does not have the same rules (or facilities) as C++ in this respect.
In C++ you CAN have initialised static const arrays of plain data types, and if you're contemplating putting them in PROGMEM then "static const"-ness may well be appropriate.
#include
static const unsigned char PROGMEM a[] = {1, 2, 3, 4}; // OK in C++ or C
With avr-gcc's implementation of C++ you can even use static const PROGMEM arrays like this as member variables of classes.
Christopher Hicks
Thanks a lot for clarifying Christopher!
I worked it out using code very much like your sample. Now I have tons of room for my data.
Another surprise was what a difference just including some float calculations made. As soon as I added a few lines dealing with floats, my code and data segments ballooned. I switched to fixed point math and got back a lot of space.
In case anyone's interested, I'm making a little controller for red, green, blue, and white LEDs for inside a jack-o-lantern for Halloween. The data I'm now storing in flash memory is the sequence of levels; 16 levels available for each LED.
Thanks again for the help!
Tim
Linking with libgcc.a or libm.a ? One costs about 3-4K, the other <1K
(but avoiding floats is a better solution anyway)
I didn't explicitly link with either by adding a new include statement. Maybe that was a mistake. It seemed strange that the code ballooned anyway - I didn't think working with floats would take that many instructions. I suspected the compiler/linker might have automatically added a lib. But I switched to fixed point before investigating. I thought I'd probably end up using fixed point, but tried floats first because it was trivial to code, would be more flexible, and it had a chance of working.
Thanks!
The key thing (if fp/math.h is to be used) is to ensure the linker gets a "-lm" (which means "(-l)ink with lib(m).a") otherwise the linker will fall back to using some 80386 optimised code out of libgcc.a which is very bad news (and sometimes just plain wrong!)
Cliff
Wow that sounds like a bad gotcha.
I'm going to repeat that to myself 10 times hoping some faint neuron will fire and I'll remember enough to save myself when I do need to use floats.
Thanks again!
Tim
If you use a Makefile created by Mfile then by default it handles the libm.a situation but if you let AVR Studio automatically create your Makefile for you then sadly (despite being told) Atmel have not managed to arrange for the avr-gcc plugin to default to linking with libm.a - which is a shame as it's Studio that beginners tend to use.
Cliff
Thanks again.
I just took the bait and clicked on the footer of your last message to read more FAQs. I'm a little embarassed to see some of what's been discussed here covered in the FAQs. But I'm glad to have read them (again I think), and to be reminded to check them in the future.
