trouble with gpio interrupt
6 posts / 0 new
Hi, I'm using EVK1101 and there is two push buttons PB0 and PB1 connected to pins PB02 and PB03.
I'm trying to make a simple program which will execute appropriate interrupt routine when I push the button PB0 or PB1 without using EIC controller.
// Include Files
#include "board.h"
#include "intc.h"
#include "gpio.h"
#include "print_funcs.h"
#include "pm.h"
// interrupt handler 1
__attribute__((__interrupt__))
static void prekidni_handler_1 (void)
	print_dbg("first handler\n");
	gpio_tgl_gpio_pin(LED0_GPIO); // Toggle the LED0.
	int i=0;
	while(i<65000)
		i++;
    gpio_clear_pin_interrupt_flag(AVR32_PIN_PB02);
// interrupt handler 2
static void prekidni_handler_2 (void)
	print_dbg("second handler\n");
	gpio_tgl_gpio_pin(LED1_GPIO); // Toggle the LED1.
	int i=0;
	while(i<65000)
		i++;
    gpio_clear_pin_interrupt_flag(AVR32_PIN_PB03);
int main(void) {
	pm_switch_to_osc0(&AVR32_PM, FOSC0, OSC0_STARTUP);
	init_dbg_rs232(FOSC0);
	print_dbg("inicijalizacija\n");
	gpio_set_gpio_pin(LED0_GPIO);//led 1 off
	gpio_clr_gpio_pin(LED1_GPIO);//led 2 on
	gpio_enable_pin_interrupt(AVR32_PIN_PB02 , GPIO_RISING_EDGE);
	gpio_enable_pin_interrupt(AVR32_PIN_PB03 , GPIO_RISING_EDGE);
	// Disable all interrupts.
	Disable_global_interrupt();
	  // Initialize interrupt vectors.
	INTC_init_interrupts();
	INTC_register_interrupt(&prekidni_handler_1,AVR32_GPIO_IRQ_0+AVR32_PIN_PB02/8,AVR32_INTC_INT0);
	INTC_register_interrupt(&prekidni_handler_2,AVR32_GPIO_IRQ_0+AVR32_PIN_PB03/8,AVR32_INTC_INT0);
	  Enable_global_interrupt();
	  while(1);
	return 0;
This code doesn't work. It works if I use only one push button and one interrupt handler, like this one:
// Include Files
#include "board.h"
#include "intc.h"
#include "gpio.h"
#include "pm.h"
	int i=0;
	while(i<65000)
		i++;
int main(void) {
	  while(1);
	return 0;
What is wrong with the first code?
Hi
Those lines seem strange to me:
INTC_register_interrupt(&prekidni_handler_1,AVR32_GPIO_IRQ_0+AVR32_PIN_PB02/8,AVR32_INTC_INT0); INTC_register_interrupt(&prekidni_handler_2,AVR32_GPIO_IRQ_0+AVR32_PIN_PB03/8,AVR32_INTC_INT0);
Second argument can be incorrect. Chech AVR32_GPIO_IRQ_0+AVR32_PIN_PB03/8. AVR32_PIN_PB03 is odd value. It seems that it is caclulated wrong. Try to use clear defined value here
Hello!
this is my example in other board, EVK1100 but is similar to EVK1101. I use the joystick of the board to simulate an interrupt external.
/** CONFIGURING THE JOYSTICK PUSH EXTERNAL INTERRUPT **/
  gpio_enable_pin_interrupt(AVR32_EIC_EXTINT_8_PIN, GPIO_PIN_CHANGE);
  //One group of interrupt has 8 interrupt.We need to known the group
  INTC_register_interrupt( (__int_handler)&joystickPush_ISR, AVR32_GPIO_IRQ_0 + (AVR32_EIC_EXTINT_8_PIN/8), AVR32_INTC_INT0);
I´m using FreeRTOS, but if you don´t use it, you haven´t to declarate the naked function.
//function to attend the interrupt external
__attribute__((__noinline__))
static portBASE_TYPE prvjoystickPush_ISR_NonNakedBehaviour( void )
	/* Now we can declare the code */
        The rest of code of interrupt
    gpio_clear_pin_interrupt_flag(GPIO_JOYSTICK_PUSH);
    /* The return value will be used by portEXIT_SWITCHING_ISR() to know if it
       should perform a vTaskSwitchContext(). */
    // False because don't change the task when the interrupt happened
    //Reset the Interrupt
	return (pdFALSE);
__attribute__((__naked__))
void joystickPush_ISR( void )
   /* This ISR can cause a context switch, so the first statement must be a
  	call to the portENTER_SWITCHING_ISR() macro.  This must be BEFORE any
  	variable declarations. */
  	portENTER_SWITCHING_ISR();
  	prvjoystickPush_ISR_NonNakedBehaviour();
  	/* Exit the ISR.  If a task was woken then a context switch will occur. */
  	portEXIT_SWITCHING_ISR();
i hope that useful for you
Gary
Hi, thanks for helping, but I solved it before with using one interrupt function and testing which button is pressed, like this:
static void prekidni_handler (void)
  if( gpio_get_pin_interrupt_flag( AVR32_PIN_PB02 ) )
  {      // PB2 generated the interrupt.
	  print_dbg("Interrupt for PB0\n");
		int i=0;
		while(i<65000)
			i++;
  if( gpio_get_pin_interrupt_flag( AVR32_PIN_PB03 ) )
  {      // PB3 generated the interrupt.
	  print_dbg("Interrupt for PB01\n");
		int i=0;
		while(i<65000)
			i++;
and this
	INTC_register_interrupt(&prekidni_handler,AVR32_GPIO_IRQ_0+AVR32_PIN_PB02/8,AVR32_INTC_INT0);
	INTC_register_interrupt(&prekidni_handler,AVR32_GPIO_IRQ_0+AVR32_PIN_PB03/8,AVR32_INTC_INT0);
Please do not busy wait in an interrupt handler ;)
Hans-Christian
:D ok
