ADC not switching channels?
2 posts / 0 new
#include
#include
#include
char volatile passes,GPLF,TF,cycles,TCharge;
int main()
char TS;	//TF=tappet flag, TS=tappet sensor, GPL=gearbox position loop flag
DDRD  |= 0x40;		//set PD6 as output (motor drive)
DDRB  |= 0x02;		//set PB1 as output (motor brake)
PORTD &= ~0x40;		//turns off PD6(motor drive)
PORTC &= ~0x40;		//turns off PC6(motor brake)
PORTC |= 0x07;		//pullup PC0,1,2
PORTD |= 0xBF;		//pullup PD0,1,2,3,4,5,7
PORTB |= 0x05;		//pullup PB0,2
ADCSRA |= 0x06;  	//ADC Prescalar set to 64 - 312.5kHz@20MHz
ADMUX  |= 0x60;		//changes ADC to 8-bit resolution, read from ADCH, sets Vref to AVCC
ADCSRA |= 0x80;  	//enable ADC
	while(1)		//main loop
		ADMUX |= 0x03;
		ADCSRA |= (1 <<ADSC);			//starts ADC conversion
		while( ADCSRA&_BV(ADSC) );	//wait for conversion complete
				if(ADCH > 132)				//sets value for Tappet Sensor
					TCharge = 1;
				while(TCharge)
				{	//A
					if( !(PINC&_BV(PINC2)) )		//checks PINC2 value and turns on drive fet
					{								//and sets the GPLF flag
						PORTD |= (1 << 6);
						GPLF = 1;
					ADMUX |= 0x04;					//PC4(BB detection), PC5(Tappet Position Sensor)
					while( GPLF == 1 || !(PINC&_BV(PINC2)) )	//start of cycle counting loop
					{	//B
							if(ADCH <= 10)				//sets value for Tappet Sensor
								TS=1;
				  				TS=0;
							if(TF != TS)				//increments cycles each time tappet sensor is true
								if(TS)
									passes = passes + 1;
									TF=TS;
							if(passes == 3)				//this segment breaks the loop after 1 full gearbox cycle
							{							//is completed unless PINC2 is still low, it also increments
								passes=0;				//cycles and checks to see if GPLF flag should be set to 0
								cycles = cycles + 1;	//which breaks the main cycle loop
									if( PINC&_BV(PINC2) )
										GPLF = 0;
									if( cycles == 5)
										TCharge = 0;
										cycles = 0;
					}	//B
					if( !GPLF )							//this segment turns of the drive fet and turns on the break,
					{	//C									//waits for 10ms and then turns off the break.
						PORTD &= ~(1<< 6);
						PORTC |= (1 << 6);
						_delay_ms(10);
						PORTC &= ~(1<< 6);
					}	//C
				}	//A
This is the program, which works absolutely perfectly if I comment out the following:
		ADMUX |= 0x03;
Yet when I use that ADC channel, and the input reads high enough for TCharge to be one, the output stays high, which means its not switching channels when I write ADMUX |= 0x04;, I don't understand why this is happening, any ideas?
You always only set bits in ADMUX, never clear some. So after the first loop run ADMUX is fixed and don't change further.
Stefan Ernst
