Optocoupler Alternative
4 posts / 0 new
I'm trying to find an alternative optocoupler to a 6N137 (LED input, logic gate with open-collector output in a DIP8 package) which will run on 3v3 supply rails. Can anyone recommend one based on personal experience? I'm not after high-speed or anything clever - just a good workhorse 'interface this real-world input to that AVR' type device which will drop into a couple of existing designs (except with lower VCC).
Take a look at the Analog Devices iCoupler device series.
http://uk.farnell.com/fairchild-... No personal experience, but I think the name matches :-)
Thanks guys.
@ArnoldB - those look ideal - I missed them first time around because the webpage said '# Voltage Vcc:5V # Logic Output Compatibility:CMOS(+5V)'. And it's always nice to support my namesake!
