Interrupt not executing all code?
5 posts / 0 new
#include
#include
#include
DDRD  |= 0x40;		//set PD6 as output (BLUE)
DDRB  |= 0x02;		//set PB1 as output (GREEN)
PORTD &= ~0x40;		//turns off PD6(motor drive fet)
PORTC &= ~0x02;		//turns off PC6(motor brake fet)
PORTC |= 0x04;		//enables pullup resistor on PC2(input)
sei();				//enable global interrupts
PCICR  |= 0x02;		//enable PCIE1 for PCINT 14-8
PCMSK1 |= 0x04;		//enable PCINT10 on PC2 (Trigger), PCMSKx enables individual pin interrupts
ADCSRA |= 0x06;  	//ADC Prescalar set to 64 - 312.5kHz@20MHz
ADMUX  |= 0x20;		//changes ADC to 8-bit resolution, read from ADCH
ADCSRA |= 0x80;  	//enable ADC
DIDR0  |= 0xFF;		//disables digital input buffer on ADC's when reading analog signals to save power
ISR(PCINT1_vect)		//interrupt vector, detects trigger
		if(~PINC2)
		PORTD |= (1 << 6);
		PORTD &= ~(1<< 6);
I do not understand why this does not work, when I push a button on PINC2(pullup resistor enabled on PC2 with button wired to ground so it pulls low), PD6 will turn on, but it never turns off after I release the button. The ISR will run twice, once when the button is pressed and held for an undetermined amount of time, then again it should run when released as the ISR runs on a pin change. Any ideas? I am new with interrupts so if there is something I am not understanding that is why.
You seem to have PORTD.6 active high.
So your ISR() will always set PORTD.6 high.
The expression (~2) is 0b1111111111111101.
You probably want to say:
    if ((PINC & (1<<2)) == 0)
More likely, it is running several times each time the button is pushed or released since switches bounce.
This makes no sense, the bit mask for PC6 would be 0x40, not 0x02. Also you haven't set that bit to output (or should this really be PORTB and PB2?).
Steve A.
ThEThInG wrote:
		if(~PINC2)
Check what exactly PINC2 is defined as. I suspect it's simply the constant 2 - and you meant something like if(!(PINC&_BV(PINC2))).
Thanks, several of those solutions worked, I had thought that PINC2 was the register value, a flat for that bit which would indicate whether it was high or low, so I thought by using that bit I could use it to determine the status of pin 2 on port C simply by reading its value.
