Creating a .txt file in AVR
227 posts / 0 new
Pages
In mmc.c your power_on almost certainly has this:
static
void power_on (void)
	PORTE |= (1<<CARDPOWER);				/* Socket power ON */
	for (Timer1 = 3; Timer1; );	/* Wait for 30ms */
	PORTB = 0b10110101;			/* Enable drivers */
	DDRB  = 0b11000111;
	SPCR = 0b01010000;			/* Initialize SPI port (Mode 0) */
	SPSR = 0b00000001;
The value written to SPCR sets just SPE (to enable SPI) and MSTR (to operate in Master mode). As the SPR1/SPR0 bits are left at default (0) this will run the SPI as fast as it can go (F_CPU / 2 because bit 0 of SPSR (which is SPI2X) is also being set)
As for the file processing. Only you know what the data is and how you want to process so I'll leave it for you to work out how you want to process it but my point was simply that if it simply consists of 7 possible data fields (ABCDEFG) that are each of 8 bytes that you could just use ONE byte at the very start of the file to say in bit flags which of the data items were "active". So rather than removing all the D's with a costly processing of the file you actually just write ONE byte at the start to effectively say "ignore D". Later when you read the data you start by reading the control byte and for any bits that are 1 (ABCEFG) you read and process the data and for any that are 0 you just skip the data.
Sure this leaves "dead" data in the file but does it really matter? We're talking SD cards which are HUGE!
In regards to your bit flag, it will not work well for me, becuase i am updating a lookup table by removing unessary address. So the list could be in 100's.
Regards
DJ
Regards
DJ
So put an "active/dead" flag on every one of the 100's of entries and when it's to be deleted simply re-write the state of the flag then, when later reading through the data ignore "dead" ones. You can also use this as a marker for the next slot to be used - when looking for a slot of new data just scan through for the first "dead" entry and re-use. It may also be possible to resurrect dead entries simply by flipping their flag back to "alive" again.
If you know the significance of the value 0xE5 in FAT (and CP/M!) filing systems you may recognise what I just described ;-)
(actually it works for resurrection in CP/M but in FAT switching the E5 may not be enough if the "first cluster" entry in the directory has been cleared)
See what i am doing is trying to make the scanning of the Lookup table short as possible, so if i had flags with dead entires, my scan would still read it.
But a entry is removed once in a while, but scanning is down much more often.
What i do is that if a new entry needs to be saved, save it to the end of file, using flseek.
DJ
Regards
DJ
But i guess your method would save me some RAM.
Regards
DJ
It's so demotivating...
i changed the Max_SS in ff.h to 1024, because with values above, the Mega32 doesn't work and formatted my Card with the same value, but i still get FR_NO_FILESYSTEM
this return value can be generated 2 times in the auto_mount-routine in ff.c
Do you have any ideas, what i could do furthermore?
Bytheway: i don't get a notification-email from avr-freaks on a new answer here. Do you have the same problem?
Add debug to the lowest level MMC sector read routine to dump each sector read as a hex dump of the entire 512 bytes and make sure the data being read by the AVR is the same as you see in WinHex
Hello
The nofilesystem-message comes from here:
if (fmt || LD_WORD(fs->win+BPB_BytsPerSec) != SS(fs)) /* No valid FAT patition is found */
  return FR_NO_FILESYSTEM;
What is to do here?
I have an ISP-Programmer, but somehow my avr-Studio can't go in Debug-mode with it.
I meant that if the AVR where you are running this code has a UART link to a PC then use printf()s via that to get a picture of what mmc.c and ff.c are "thinking" inside.
(Cliff using a different ID)
Unfortunately i don't have a UART. I'm doing my debugging with a few LEDs.
So i can visualize Byte, letting one LED blink in a for-loop.
Perhaps i could send my code to you, that it can be verified, if the code is not working or sth. else. Is that possible?
Sure but which model of AVR is it for?
For a Mega32.
Oh right, I may have one somewhere but if not I'll try it with mega16 as I definitiely have those. ZIP or RAR your project and then either attach it to a post here or to a PM (to "clawson" - not this account)
Cliff
That's because an ISP-programmer simply isn't a debugger.
a Mega32
The ATmega32 most certainly has a UART.
No. ;-) I mean, that i have no possibility, to use UART on my Computer. I just have USB-Ports, so i need an adapter for UART to USB, but i didn't really was behind looking for such a thing.
What does this expression stand for?(from ff.h)
#define	LD_WORD(ptr)		(WORD)(*(WORD*)(BYTE*)(ptr))
In the FAT-FS-User-Forum a user comes with this statement:
if (LD_WORD(&fs->win[BS_55AA]) != 0xAA55)
   return 2;
So he compares sth. at the end of the Bootsector, as i understood so far. Bur for a C-Beginnner, this looks a little cryptic. Please help me out.
Thank you
It's just being used to pick up a 16bit value from an 8bit array. He could have done it as:
if ((fs->win[BS_55AA] != 0x55) || (fs->win[BS_55AA+1] != 0xAA)) return 2;
but treating 'ptr' as a BYTE pointer but then casting a WORD pointer interpretation onto it and picking up that word for a single test of 55AA in theory reduces the complexity (and quite possibly the code size) of the test.
Cliff
Hi Cliff
Whats the best way to calculate a write and read time.
At moment i am using the JTAG debugger to program the device and also run it.
Would i be correct in saying that once i click on the play button, i get a bit more delay then the actual AVR has, due to PC etc.
DJ
Regards
DJ
Usual way to time stuff is... write a for() loop that does an operation (say) 10,000 times, time it with the sweep second hand on your watch then finally divide the time you measured by 10,000 (or whatever)
Cliff
I am trying to move a file from one folder to another. This is fairly easy using.
f_rename()
E.g.
f_rename("oldname.txt", "dir1/newname.txt");
Now if i hard code all the dir, it works. But if i want a under to specify the folder, how would i do that? At moment it is dir1, but i would like to choose or even have sub dire.
DJ
Regards
DJ
If the dirname is variable but the filename ("newname.txt") is fixed then why not just strcat() one onto the other before the f_rename()?
Just did that before your post and its working.
Regards
DJ
f_unlink, i can delete a file, but not a whole directory(folder).
DJ
Regards
DJ
Normally you should be able to delete an EMPTY directory (it's the same in DOS). So you just have to delete all the files in it first and then the directory last. (possibly recursively)
Ah, yes. The fine art of recursive functions on an AVR.. :wink:
The code to delete a complete directory subtree is something that every CS student should have to do to get an exam. It's been a while since, but IIRC this is how it should go (sketchy, no specific OS but rather some "pseudo"-names for OS API functions that should be easily located for the specific case:
void removeDirectory(String path)
   foreach (file in path)
      if (file.type == FILE) {
         delete(path+file.name);
      else if file.type == DIRECTORY) {
         removeDirectory(path+file.name);
      else {
         // Handle this gracefully...
   delete(path);
As I hinted, recursive functions and AVR don't always go well together. For an ATmega128 and a directory tree that isn't very deep it might work well, but...
Johan,
Surely the art of recursion is to keep the usage of locals to the absolute minimum necessary? If this removeDirectory() was creating a local filename buffer of 256 bytes for the longest possible LFN each time it were called then I agree it could eat RAM quickly, but this might actually be one of the few places where there's an argument for malloc() and only creating RAM buffers of exactly the required size?
Cliff
Not "the art", merely "one art". Others include eliminating "tail recursion". In the case above that might be possible, but it's at the end of the work day and my brain don't want to think about what would be needed. Certainly that all ordinary files are reported before sub-directories (in the enumeration / the foreach pseudo statement).
And if the system is really memory challenged, then even if you would have all directory names being just one character, you'd build up stack frames with return addresses etc.
I got two questions..
1st
I have a network , with many nodes. Each file will have node information. So everytime a node changes its status the file will be updated.
If there is no change there will be no updat.
My AVR will have a RTC.
So everytime i compare my file to a node, i would like the time and date information to be replaced in the file. This should happen even if node has no change in its staus.
2nd
I need to scan a directory, i am using
f_readdir
What order will my scan be, is there away of reseting the counter or index value. So for example after scanning the directory it comes to the 5th file, but now it would like to scan from 0, rather then 6th entry.
Is there away of finding the total files, without scanning and keeping a count.
By the way i am declaring more Files, but the RAM does not increase. Even thou i have 4 files, not all will be opened at the same time. Worst case there will be 3, so would you say i should worry about files more then 3 being declared even thou no more then three will be opened at one given time.
DJ
Regards
DJ
The order the file entries appear in the directory sectors. If the files are created consecutively with no deletions then it will be in creation order but as soon as you start deleting files their directory entry is set to 0xE5 and the next time the file system creates a file it will use the first 0xE5 entry it finds. So the order could become very mixed and near unpredictable.
Yes, you are the one creating and deleting. Each time you create one increment the counter and each time you delete one decrement it.
Simply not true.
FIL files[4];
occupies twice the space of
FIL files[2];
As this is a static allocation it's got nothing to do with whether the FIL structures are actually used by f_open'ing or not.
I am declaring files like this
Fil file1,file2,file3
DJ
Regards
DJ
In regards to scaning, i want to be able to index for my GUI,so once i select a file i should know what file is selected.
DJ
Regards
DJ
hello guys,
i've done a sketch, that you can have a look at my circuit.
The question is thou: How have you done it? What's eventually wrong with my circuit?
Thank you
Did you look at avr_mmc.png in the FatFs examples .zip file?
I just copied that almost exactly to be sure the code as delivered would just work. That included having the INS and WP support.
PS When I get a chance I am going to try that code you sent - my STK500 is tied up doing something else right now.
BTW you have read the Getting SD/MMC working tutorial haven't you?
Cool, the tutorial seems quite interesting...
I will check this the next days.
I've included all things from the Tutorial, but still: NO_FILESYSTEM. ARG!
Returnvalue still comes from:
fmt and LD_WORD... both have a value of zero.
zero for fmt means, that it is a FAT-partition-->looks good.
But the value of fs->win... should be 512, but it's zero too.
I should mention, that, because i don't use UART, i removed all files and functions related to this.
Update: Shit! if i put these 2 lines as comment, then the result is FR_INT_ERR. Damn, why can't this shit just work?!
Hello?
Anybody out there?
I created "abc.txt" on my card and set the f_open-flags to open_existing and read, but the same failure(no filesys) occurs.
do i need the RTC for my project? i hope not, because i deleted all parts concerning this.
Nope, you don't need RTC - you just stub the function where its interrogated to always return the same result. The upshot will be that all your files (if you ever manage to write them) will have the same date/time stamps.
Sorry, but I didn't understand your post, because there are several functions in rtc.c and i don't know, which function i have to stub. What's with these, with the I2C-interface? Delete?
Did you get my pm where i pleased you, to send me your project code?
How can i know if i am running on max speed.
I made 50 files that have 50 bytes of variables.
When i read the each file and output a certain variable from the file it takes few seconds for it to complete, does this timming sound correct?
DJ
Regards
DJ
No, reading a 50 byte file should be much quicker than that. Are you sure your code is not blocking elsewhere?
Well i am using the standard UART to output.
But i can show you my reading code, what i do to read it later on today, once i get on my PC.
Maybe i am doing somthing wrong. Same happens when i am writing 50 bytes.
By the way i am reading like 50 files? Opening a file, reading the variable , displaying it, and then going to the next file.
Regards
DJ
Regards
DJ
displaying it,
Sounds like a long process. Cut that bit out and see how long the overall read of 50 files takes then divide by 50.
Is there away to calculate accuratly how long it takes, According to my calculations
It takes 4 seconds, but lets say 5 seconds.
That is 5000ms.
So 5000ms for 50 files files, So each files is 100ms.
100ms for 50 bytes, so each byte is 2ms .
This also include all the UART.
Does this sound right?
DJ
Regards
DJ
Like I say forget the UART as that's a huge block on performance. Just do:
uart_print("start\n");
for (i=0;i<5000;i++) {
 accessfile(i);
uart_print("finish\n");
then just time on your watch between start and finish then divide the elapsed seconds by 5000 (in this case) and that tells you how long accessfile() takes for one file.
Cliff
I will give this a try
Regards
DJ
Hi OK
I am now reading about 50 files, where each file has 50 bytes.
I have done the START and END display in the UART to indicate when to start the time and when to end the time.
My First test should it to be 1min and 17 secs, while the next took 30 seconds. I will explain bit futher down why there was such a big time improvment.
But does 30 secs sound right. This is 30 / 50 =0.6 seconds a file. Would this imply the time for 512bytes (sector) or 50 bytes(acutal data). If 50 bytes , then each byte takes 0.012 seconds.
Now my code
uart_puts_("START");
for (a=0;a<51;a++){
read_device(a);
uart_puts_("END");
Read_device, is reading a perticular file type.
int read_device(unsigned long long address)
int result;
UINT ret,*ret_add;
ret_add=&ret;
result=0;
//hexstring(name, (unsigned long long)address);
//f_result = f_open(&file1,name, FA_READ |FA_OPEN_EXISTING);
f_result = f_open(&file1,"a", FA_READ |FA_OPEN_EXISTING);
if (f_result == FR_OK) {
f_read(&file1,read_data,sizeof(read_databuffer),ret_add);
f_close(&file1);
result =1;
eturn result;
I am reading and closing the same file "a", rather then all the files. This is because the contents of the files are indenical. What this function is doing is, it reads long integer (hex file name) and converts it to string. Now i felt this hex to string was slowing things down. So i have commented out this call to this function.
Bu this is the function
char hexdig[] PROGMEM = { "0123456789ABCDEF" };
void hexstring(char * buf, unsigned long long n) {
  uint8_t i;
  buf[16] = 0;
  for (i=0; i<16; i++) {
    buf[15-i] = pgm_read_word(&hexdig[n & 0x0f]);
    n >>= 4;
So does this sound correct, in regards to my time issue?
Regards
DJ
Regards
DJ
You are kidding yourself if you think there's only one 512 byte sector read involved in reading 50 bytes from a file! Try putting a UART debug output that displays each time disk_read() in mmc.c is called and then call your read_device() function just once.
Using 50 files each of 50 bytes may get FatFs to do the indexing for you but it is HUGELY inefficient compared to one file of 2,500 bytes where you index the data yourself.
Cliff
So would you say all my timing is all correct.
I wounder if changed the freg from 8mhz to 20 mhz, will it make a differnce or does this FATfs scale the freq down.
DJ
Regards
DJ
I was orginally thinking about keeping all data in one file and then have very large datastructure with all nessary information.
This way maybe every 200 byte could be a seen as new entry(compared to new file).
My only problem is what variable type to use if i want to read say the middle of 10mb file, how would i represent that i want to read the byte that is 5mb. What variable would be big enough?
Regards
DJ
Regards
DJ
You should get some good books about learning C if the answer to that kind of question is not obvious. Personally I'd fseek to some multiple of sizeof(struct) and then cast a struct interpretation onto the buffer-full just read. (maybe different struct types if the data differs). For example:
typedef struct {
 int rec_num;
 char name[40];
 int age;
 int year_birth;
 int month_birth;
 int day_birth;
} data_record_t;
data_record_t * pdata;
int rec_size = sizeof(* pdata);
uint8_t buffer[N];
fin = fopen(file, "rb");
fseek(fin, rec_size*rec_N);
fread(buffer, rec_size, fin);
pdata = (data_record_t *)&buffer;
if (pdata->year_birth> 1970) {
Pages
