make error [Solved]
4 posts / 0 new
OS WinXp
Programmer notepad
avr-gcc 3.4.5
here is the error, I amm unable to sort out
make.exe: *** No rule to make target `abcasm.o', needed by `main.elf'. Stop.
Any hints to solve it!!
Thanks in advance.
Is there an abcasm.c (or perhaps an abcasm.S)? Did you name it correctly (alt spell the name correctly in the makefile)? Remember that Gnu Make is case-sensitive.
If this does not help, then attach your makefile to a post here.
Great input.
Fixed.
I was referring to abcasm.S file in the sub directory
I initially used
ASRC = abcasm.S
With your hit, I modified it to
ASRC = ./foldername/abcasm.S
It worked wit no errors.
Thanks Johan...
I live to serve.. :wink:
Bonus points awarded to you for these:
1. Marking the issue as solved.
2. Reporting back on what the solution was.
