Trampolines not supported - Help needed please!
4 posts / 0 new
Bear with me - I'm an occasional programmer - .. plenty of cutting and pasting from working projects when it works, great - when it doesn't it's a pain.
I've NEVER come across this INTERNAL compiler error before and it occurs when I use my timer routine which uses function pointers.
I've been using this function/method for ages and it works fine with a MEGA168 and others .. but I've just ported to a MEGA32 and the compilation fails.
Here's the call which causes the error:
setup_timer (timer_no,time_value,calledfunction,callingparam );
Here's the Definition:
void setup_timer (unsigned char,unsigned short, void(*)(unsigned int),unsigned int);
The function stores the data in a table and starts a timer.
A timer function is then regularly called and uses the data to execute the function when the timer expires.
I'm stuck for a solution unless somebody can assist or give some clues.
And the error message is?
Are you by any chance using nested functions? (You can't do that in avr-gcc).
This looks strange:
And lastly a minor terminology thing:
Actually, that is a declaration. A definition requires a function body. (A prototype/function header is a declaration. An implementation is a definition.)
Begs yer pardon ...
Declaration indeed ..
The error message was ' Trampolines not supported' as per the message title.
Declarations I find tricky - what with the function calls etc. That was from an old project - used many times and works.
However, I'm happy to be told the correct declatarion for my function. ..
Interestingly enough .. I have a mega32 project that worked with it.. then cutting it down and editing in an attempt to make it the same as the required project - eventually the error returned.
So, clearly there's somethign in the whole code structure which the compiler hates .. incidentally - it does message with somethign like 'make a bug report', so I guess the compiler is loosing it somewhere.
In a java group that I used to follow they would often ask you to provide an SSCCE. Some things in that article are not necessarily applicable to other languages/C/embedded/etc. But in general it summarizes pretty well what people should normally do when reporting a problem or asking for help.
Eugene
