Puttin 2 devices on mega8A usart.
2 posts / 0 new
I am new to microcotrolers. Can I put two devices on the usart pins of a mega8A. And if I can what do I need to do C++ wise.
Device 1 is an RF transmitter module from Sparkfun.
Devie 2 is a rangefinder module that puts out a serial output, and needs a 2byte command.
What other info do you guys need to help me sort it out?
That depends, are you talking about asynchronous serial or something like SPI?
For async, there are two main problems:
#1 the end-device's transmit pin being active driven, preventing either device from transmitting
#2 sending data to the corresponding device from the microcontroller, without the other device doing anything with it.
SPI solves this by allowing multiple slaves, selected by a chip-select pin.
You can emulate this behaviour for async by using a quad-buffer with grouped or individual output enable pins. By enabling the correct two ports of the buffer, you can select which device to talk to.
