tiny2313 resets(?) after INT1
6 posts / 0 new
Hi 'freaks,
I'm working on a LCD 16x1 for error codes. The LCD works pretty good so far, now I'm programming a data/clock 2-wire communication where INT1 functions as clock-input.
Problem is: When INT1 is finishes my program returns to the start of main(). It does this in reality and in the simulator.
I've put the ISR code above another function but the programm still jumps to the first line of main(). Here is the code without the LCD routines and defines.
Is my init() wrong? I've read the datasheet part about external interrupt more than once and can't find a flaw :(
//                                includes and subroutines
#include
#include
#include "my_bit.h"
#include "my_types.h"
//                                  subroutines
void init (void)
//[PortB]
    DDRB  = 0b11111111;     //PortB out
    PORTB = 0;
//[PortD]
    DDRD  = 0b01110000;
    PORTD = 0;
//[Interrupts]
    setBit(PCMSK, Bit7);    //use PD3 as INT1
    setBit(GIMSK, Bit7);    //INT1 is used as external interrupt
    setBit(GIMSK, Bit5);    //pin change interrupt enabled
    setBit(MCUCR, Bit2);
    setBit(MCUCR, Bit3);    //INT1 triggers on rising edge
    sei();
//                                     interrups
ISR(INT1_vect)              //external interrupt
    volatile uInt uInt_IRQcounter;
    LCD_sendcommand(0x01);  //display clear
    LCD_setDDRAM(0x00);
    uInt_IRQcounter++;
    LCD_writedata(uInt_IRQcounter+0x30);
//                                     main
int main()
    init();
    LCD_init();
    LCD_writedata(0x30);
PCMSK has nothing to do with INT1, it controls the PCINTx interrupts.
Again, this is for the PCINT interrupt. Remove these two lines.
Steve A.
your interrupt init does not match your comments, your comments talk about INT1, but you are initializing for a PCINT (Pin-Change Interrupt) as well.
No, that line enables Pin PB7 as a pin-change interrupt source
These lines are enabling the bits as described, note you are also enabling the pin-change interrupt
This is correct as well.
Problem is while you do have an interrupt handler defined for INT1, you don't have one for the PCINT, as a result any changes on PB7 will cause your AVR to try and execute an interrupt that is not there, resulting in the AVR resetting (in this case) [this is because there are no other interrupts defined in the vector table that appear after the PCINT entry]
Side note:
The order of your C functions in the source code has nothing at all to do with what executes first after a reset. The startup code that the linker inserts will always call main() no matter where it resides, and what possibly precedes it, in your source code.
As you are using GCC then why on earth refer to control bits in SFRs simply as "Bit5" or "Bit7"? You, in 3 months, like us now, will have to dig out a datasheet to be able to understand what your code is doing.
would be far more readable as:
    setBit(PCMSK, PCINT7);    //use PD3 as INT1 - error - you cannot reassign pins
    setBit(GIMSK, INT1);    //INT1 is used as external interrupt
    setBit(GIMSK, PCIE);    //pin change interrupt enabled - error - no ISR and should not use
In which case your error of enabling two interrupts and providing just one ISR() would have been quickly obvious. See "catch all" on this page:
uh yeah, not using the GCC names was stupid. Thanks for all the corrections and hints :)
[edit]
The interrupt now works as wanted. But I'll have to change my macros. They don't work with the GCC names. They need a "1" for Bit0 and "2" for Bit1 etc..
