Using the XMega128A1 RTC without using any interrupts?
4 posts / 0 new
Anyone using the XMega128A1 RTC without using any interrupts or events?
The manual tells us this:
17.2.2 Interrupts and events The RTC can generate both interrupts and events. The RTC will give a compare interrupt request and/or event when the counter value equals the Compare register value. The RTC will give an overflow interrupt request and/or event when the counter value equals the Period register value. The overflow will also reset the counter value to zero.
I can't find anything in the documentation that says what happens with the RTC if you do not enable RTC interrupts or events.
I made the apparently invalid assumption that the counter would continue to count after it overflowed. What I am seeing is that the counter stops as some arbitrarily small value generally less than 100 counts, probably due to the clock domain synchronization. It takes 3 CPU clocks to read from the RTC clock domain, takes 3 RTC clocks to write to the RTC domain; note the difference between the two easy to miss.
Can anyone confirm this is how the part is, or is meant to operate, and the documentation is just a bit lacking in this case?
Bob,
I just disabled interrupts. The RTC keeps counting from 0 to RTC_CYCLES_1S (PER register) based on the example. In my case, RTC_CYCLES is 63. Are you using a larger value?
RTC_Initialize( RTC_CYCLES_1S, 0, 0, RTC_PRESCALER_OFF_gc );
Let me know if you want me to try something else.
PRESCALER_OFF? That stops the RTC.
  CLKSYS_RTC_ClockSource_Enable( CLK_RTCSRC_TOSC_gc ); /* 1024 Hz = 32kHz external crystal /32 */
  while( RTC_Busy() )
  RTC.PER  = 2;
  RTC.COMP = 2;
  RTC.CNT  = 1234;
  //  RTC.CTRL = RTC_PRESCALER_DIV1024_gc; /* Rollover in 18 hours and 12 minutes */
  RTC.CTRL = RTC_PRESCALER_DIV1_gc; /* Rollover at 64 seconds */
Is what I have, was not using the rtc_driver code other than for busy().
Unit just ended the 18 hour cycle, where it stopped counting.
Must stop on match, regardless of interrupts or events being used.
yeah.. I was just looking at the PER value. I stop the RTC before intializing it in my code. Here is what I have. It keeps rolling over in my case, but I'm setting RTC.COMP to 0 (not sure if that matters). The manual does mention
If the COMP value is higher than the PER value, no RTC Compare Match interrupt requests or events will ever be generated.
do {
      /* Wait until RTC is not busy. */
} while ( RTC_Busy() );
/* Set internal 32kHz oscillator as clock source for RTC. */
CLK.RTCCTRL = CLK_RTCSRC_RCOSC_gc | CLK_RTCEN_bm;
do {
/* Configure RTC period to 1 second. */
RTC_Initialize( RTC_CYCLES_1S, 0, 0, RTC_PRESCALER_DIV1_gc );
/* Turn on internal 32kHz. */
OSC.CTRL |= OSC_RC32KEN_bm;
do {
   /* Wait for the 32kHz oscillator to stabilize. */
} while ( ( OSC.STATUS & OSC_RC32KRDY_bm ) == 0);
enable interrupts...
