My mkii didn't come with the board called "STK500 JTAG Adapter" (it plugs into an expand0 on the stk500 and gives two 10 pin headers). Q#1: Is this normal?
Also, it did come with a squid cable and a cable that converts the 10 pin header to a 6 pin which looks like it is setup for a SPROGx connector on the STK500.
Q#2: Assuming I want to try to debug in DW, do I only need to connect it to SPROGx ? Then it will do ISP/DW through that connection?
Q#3: Do I still plug the STK500 serial in to the PC? How does AVR Studio 4 know which to use for programming, STK500 or JTAGICE mkII?
Q#4: Is there a document or tutorial somewhere on using these two together?
Alan
