How do you debug on a small chip with -O0 ???
13 posts / 0 new
So, I've put together a very small program from the example in the first tutorial.
It is 72 bytes when using -Os, but when I use -O0, it jumps to 3130 bytes! If I comment out the _delay_ms(1000); it goes back to a reasonable 104 bytes.
Two questions -
1. Why does it jump to over 3K ?
2. How do you debug on chips that have limited memory like a tiny13a with 2K ?
Alan
#define F_CPU 4000000UL
#include
#include
int main()
DDRB=7;
if (PINB & 8)
PORTB |= _BV(0);
else PORTB &= ~(_BV(0));
_delay_ms(1000);
The _delay_ms() function (actually a macro IIRC) uses floating point maths to determine the exact number of cycles needed to be wasted to get the desired delay. Under -Os, an optimisation called "constant folding" causes this floating point value to be calculated at compile time, and only the calculated value to be used when the program runs.
With -O0, this optimisation is turned off and the compiler is forced to include the entire floating point library to do the calculation at runtime. Not only does this cause a hefty program size increase, it also causes the delay to be much longer than desired due to the calculation overhead.
Debugging with -Os is an art you will learn; a common trick is to declare variables of interest with "volatile" so that the compiler is forced to emit code for them rather than optimising them out completely if possible, so they can be watched in AVRStudio.
- Dean :twisted:
Hello
I am wanting to find out more information on compiler optimizations. What the compiler tends to remove / optimise and the resulting side effect to the code.
Some debugging tricks with Optimization level 0s, such as the volatile definition of variables, are useful, but what are other good methods of debugging.
Thanks in advance.
Derek
alank2, why do you use other types of optimization instead of -Os? Especially on the small chip? I always use -Os level as the best one.
The usual argument for using the horrendous -O0 setting is that it makes the code "easier to debug". Admittedly (as shown by this very thread) you are then debugging an entirely different program but at least you don't have to go hunting for the variables and the Watch window can be used.
Cliff
you can define a bigger chip in debuge mode and use your tiny13 with development
I love Digital
and you who involved in it!
Cliff
I'm affraid that debugging the code with the -O0 level you don't see the truth. To program uC you have to compile the code with the different -Os level. So the code inside the uC will be another.
I was trying -O0 to make debugging followable. Are there levels between -O0 and -Os that are still followable, but not quite so bloated?
Also, could the timer code be compiled as a library using -Os and then my main program compiled as -O0 so it would be easier to debug, but the timer code wouldn't be affected? I've done this with other C development, would it work on this platform?
Alan
There is the level -O1. This has less optimaization turned on, but the its much more like -Os than -O0.
Making some or even all variables volatile allready helps a lot to make the code easier to debug.
Its allso possible to turn of some types of optimization off individually.
I also strongly recommend this as well.
Those delay functions have limitations that are strictly spelled out in the AVR-LibC User Manual. One limitation is that optimization must be turned on. But that doesn't mean that the only optimization is -Os. Try using -O1.
Or just learn to debug optimised code as the rest of us have done. Using the mixed C+Asm view in the debugger is a very useful tool - in this as you can see whether intermediate variables have been discarded or moved into register only usage.
You can temporarily split subroutines into individual source files, compile everything Os, change to O0 option and make edits to the files you want to debug so they will recompile.
Or just put the O0 option on individual files.
