Multiple LCD Problem
23 posts / 0 new
Hey all I have been working on a new little project with three seperate LCD's showing different information.
I have 2 2x16 lcd's and 1 4x16 lcd, they are both controlled by a hd44780 controller.
I have the following code, strongly based of peter fluerys library, I can get them to initialize and one lcd to display it's initial screen but thats it.
Lcd's are in 4 bit mode
data lines, R/W, RS, are all shared by the lcds and are on PORTC data lines are on , bit 4,5,6,7 RS on bit 3, R/W on bit 1
Enable pins are located on PORTA bit 1,2,3.
	lcd_init(LCD_DISP_ON);
	Lcd_1_int();
	Lcd_2_int();
	Lcd_3_int();
	while (1)
		    Lcd_Update1();
void Lcd_Update1(void)
	LCD_E_PIN = 1;
	lcd_gotoxy(0,1);
	_delay_ms(1000);
	sprintf(Temp2, "Time Left - %.2d",TimeJ1);
	lcd_puts(Temp2);
void Lcd_3_int(void)
	LCD_E_PIN = 2;
	_delay_ms(2);
	lcd_clrscr();
	sprintf(Temp1, "        Test0\n");
	sprintf(Temp2, "    Test1\n");
	sprintf(Temp3, "  Test2\n");
	sprintf(Temp4, "   Test3\n");
	lcd_gotoxy(0,0);
	lcd_puts(Temp1);
	lcd_puts(Temp2);
	lcd_puts(Temp3);
	lcd_puts(Temp4);
void Lcd_1_int(void)
	LCD_E_PIN = 1;
	_delay_ms(2);
	lcd_clrscr();
	lcd_gotoxy(0,0);
	sprintf(Temp1, " Test4\n");
	sprintf(Temp2, "   Test5");
	lcd_puts(Temp1);
	lcd_puts(Temp2);
void Lcd_2_int(void)
	LCD_E_PIN = 3;
	_delay_ms(2);
	lcd_clrscr();
	lcd_gotoxy(0,0);
	sprintf(Temp1, " Test7\n");
	sprintf(Temp2, "   Test8");
	lcd_puts(Temp1);
	lcd_puts(Temp2);
void toggle_e(void)
	PORTA |= _BV(LCD_E_PIN);
	lcd_e_delay();
	PORTA &= ~_BV(LCD_E_PIN);
void lcd_write(uint8_t data,uint8_t rs)
	if (rs) {   // write data   (rs=1, rw=0)
		PORTC |= _BV(3);
	} else {	// write instruction (rs=0, rw=1)
		PORTC &= ~_BV(3);
	PORTC &= ~_BV(1);
	DDRC |= 0xF0; // sets Pins 4,5,6,7 to output
	//output high nibble first
	PORTC &= ~_BV(7);
	PORTC &= ~_BV(6);
	PORTC &= ~_BV(5);
	PORTC &= ~_BV(4);
	if (data & 0x80) PORTC |= _BV(7);
	if (data & 0x40) PORTC |= _BV(6);
	if (data & 0x20) PORTC |= _BV(5);
	if (data & 0x10) PORTC |= _BV(4);
	toggle_e();
	//output low nibble
	PORTC &= ~_BV(7);
	PORTC &= ~_BV(6);
	PORTC &= ~_BV(5);
	PORTC &= ~_BV(4);
	if (data & 0x08) PORTC |= _BV(7);
	if (data & 0x04) PORTC |= _BV(6);
	if (data & 0x02) PORTC |= _BV(5);
	if (data & 0x01) PORTC |= _BV(4);
	toggle_e();
	//all data lines high (inactive)
	PORTC |= _BV(4);
	PORTC |= _BV(5);
	PORTC |= _BV(6);
	PORTC |= _BV(7);
uint8_t lcd_read(uint8_t rs)
	uint8_t data;
	if (rs)
		PORTC |= _BV(3);		//RS=1: read data
		PORTC &= ~_BV(3);		//RS=0: read busy flag
	PORTC |= _BV(1);			//RW=1: read mode
	DDRC &= ~_BV(4);
	DDRC &= ~_BV(5);
	DDRC &= ~_BV(6);
	DDRC &= ~_BV(7);			//configure data pins as input
	lcd_e_delay();
	data = 0;
	if ( PIN(PORTC) & _BV(4)) data |= 0x10;
	if ( PIN(PORTC) & _BV(5)) data |= 0x20;
	if ( PIN(PORTC) & _BV(6)) data |= 0x40;
	if ( PIN(PORTC) & _BV(7)) data |= 0x80;
	lcd_e_delay();				//enable 500ns low
	lcd_e_delay();
	if ( PIN(PORTC) & _BV(4)) data |= 0x01;
	if ( PIN(PORTC) & _BV(5)) data |= 0x02;
	if ( PIN(PORTC) & _BV(6)) data |= 0x04;
	if ( PIN(PORTC) & _BV(7)) data |= 0x08;
	return data;
uint8_t lcd_waitbusy(void)
	uint8_t c;
	while ( (c=lcd_read(0)) & (1<<LCD_BUSY)) {}
	delay(2);
	return (lcd_read(0));
void lcd_newline(uint8_t pos)
	uint8_t addressCounter;
	if ( pos < 0x14 )
		addressCounter = 0x40;
	else if ( (pos >= 0x40) && (pos < 0x54) )
		addressCounter = 0x14;
	else if ( (pos >= 0x14) && (pos < 0x40) )
		addressCounter = 0x54;
		addressCounter = 0x00;
	lcd_command((1<<7)+addressCounter);
void lcd_command(uint8_t cmd)
	lcd_waitbusy();
	lcd_write(cmd, 0);
void lcd_data(uint8_t data)
	lcd_waitbusy();
	lcd_write(data,1);
void lcd_gotoxy(uint8_t x, uint8_t y)
	if ( y==0 )
		lcd_command((1<<7)+0x00+x);
	else if ( y==1 )
		lcd_command((1<<7)+0x40+x);
	else if ( y==2 )
		lcd_command((1<<7)+0x14+x);
		lcd_command((1<<7)+0x54+x);
int lcd_getxy(void)
	return lcd_waitbusy();
void lcd_clrscr(void)
	lcd_command(1<<0);
void lcd_home(void)
	lcd_command(1<<1);
void lcd_putc(char c)
	uint8_t pos;
	pos = lcd_waitbusy();
	if (c=='\n')
		lcd_newline(pos);
		lcd_write(c, 1);
void lcd_puts(const char *s)
	char c;
	while ( (c = *s++) ) {
		lcd_putc(c);
void lcd_init(uint8_t dispAttr)
	DDRC |= 0xFF;
	DDRA |= 0xFF;
	delay(16000);
	PORTC |= _BV(5);
	PORTC |= _BV(4);
	PORTA = 0x0F;
	lcd_e_delay();
	PORTA = 0x00;
	//toggle_e();
	delay(4992);
	PORTA = 0x0F;
	lcd_e_delay();
	PORTA = 0x00;
	//toggle_e();
	delay(64);
	PORTA = 0x0F;
	lcd_e_delay();
	PORTA = 0x00;
	//toggle_e();
	delay(64);
	PORTC &= ~_BV(4);
	PORTA = 0x0F;
	lcd_e_delay();
	PORTA = 0x00;
	//toggle_e();
	delay(64);
	lcd_command(0x08);
	lcd_clrscr();
	lcd_command(((1<<2) | (1<<0x06)));
	lcd_command(dispAttr);
It won't let me Post the delay routine but it is identical to the one thats in peter fluery's lcd library
Any suggestions on were I have gone wrong???
Any suggestions on were(sic) I have gone wrong???
You've tried to get three displays working before you got one display to work.
Don
When I // the other 2 displays out the code works fine it's when I add a second and or third that the problem arrises!!
So debug your code.
When you where here last time you didn't want to listen to advice. Has that changed in the meantime?
I would suspect lcd_waitbusy() function.
It makes LCD data lines output.
To make sure I would try for example
lcd_waitbusy(void)
_delay_ms(20)
I am certain that the wait busy is the problem. You are sending all three displays into read mode at the same time and their outputs are conflicting. If you use separate R/W lines for each and only put one into read mode at a time it should work. Otherwise, Visovian's solution will work as well.
Steve A.
the HD44780 data sheet shows the output driver active in read mode during E high phases only. That's not conflicting.
But sometimes the outputs don't drive high. Put the pull up resistors on when you read the LCD.
Maybe lcd_e_delay(); is removed by optimizer.
Why do you handle each bit instead of half bytes?
Does that mean "each" displays tested by itself works OK.
Where and how is LCD_E_PIN declared ??
Lee
Lee -.-
From the very first post:
It is also quite clear from the code.
Steve A.
Hi Steve,
I do not see whether it is "declared" as a variable or "defined" as a constant in the first post and the code does not make the hardware allocation any clearer for me.
If it is a variable, setting it to 3 will actually enable two bits on PORTA. (#define _BV (1 << (bit))
If it is a CONSTANT, I did not think it was permissible to assign a value to it at run time.
But I could be wrong and whilst I am alive, I believe I will learn something new every day and that is why I watch this forum and learn from greater minds than mine.
Incidentily the lcd_newline() function will probably need to know which LCD it is operating on or how many lines it has.
Lee
Lee -.-
Since he uses it thus:
   LCD_E_PIN = 1;
then it is obviously a variable. And whether that variable is declared as an int or a float is inconsequential since it will be converted to an int when it is used here:
No it won't. It will set bit 3 of PORTA.
Steve A.
I have tested and found something else.
In read mode (RW=1) there are strong levels on data lines even when E=0. In no case are the lines tristating.
in that case
I have tested and found something else. In read mode (RW=1) there are strong levels on data lines even when E=0. In no case are the lines tristating.
the RW line must be separated for each display too.
Okay so I need to Isolate the RW line I will give that a shot!
I tried removing the waitbusy and put in the delay as suggested and the first lcd works perfectly now but still no response from the others
LCD_E_PIN is declared as a int variable!
each display is fully functional and have tested them individually!!!
As the next step I would disconnect RW of all LCDs from AVR and ground them. Then test the code with delay.
Besides, there are LCD code examples that do not use RW at all.
Well I got most of it going...turns out the other 2 LCD's weren't initialized, in order to get them to work I have to take then enable lines from the 2nd and 3rd LCD and combine them with the enable line from the first lcd then reset the Mega32, also found out for some unknown reason the lcd enable lines are located on bits 1,3,4....I can't figure that part out.....
   DDRC |= 0xFF;
   DDRA |= 0xFF;
   delay(16000);
   PORTC |= _BV(5);
   PORTC |= _BV(4);
   PORTA = 0x0F;
   lcd_e_delay();
   PORTA = 0x00;
   //toggle_e();
   delay(4992);
   PORTA = 0x0F;
   lcd_e_delay();
   PORTA = 0x00;
   //toggle_e();
   delay(64);
   PORTA = 0x0F;
   lcd_e_delay();
   PORTA = 0x00;
   //toggle_e();
   delay(64);
   PORTC &= ~_BV(4);
   PORTA = 0x0F;
   lcd_e_delay();
   PORTA = 0x00;
   //toggle_e();
   delay(64);
   lcd_command(0x08);
   lcd_clrscr();
Note that up to line
lcd_command(0x08);
you toggle all three E-lines (PORTA.1, PORTA.2, PORTA.3.
   PORTA = 0x0F;
   lcd_e_delay();
   PORTA = 0x00;
OK so far.
But remainig part of init you do only for one LCD according to value of LCD_E_PIN which I guess is "1" as you say LCD1 works.
It is because in func lcd_command() => lcd_write() => toggle_e() you toggle only one E line.
I would try this
(with RW lines grounded)
//replace these functions:
int lcd_init(uint8_t dispAttr)
   DDRC |= 0xFF;
   DDRA |= 0xFF;
   delay(16000);
   PORTC |= _BV(5);
   PORTC |= _BV(4);
   toggle_e();
   delay(4992);
   toggle_e();
   delay(64);
   toggle_e();
   delay(64);
   PORTC &= ~_BV(4);
   toggle_e();
   delay(64);
   lcd_command(0x08);
   lcd_clrscr();
   _delay_ms(10);
   return (1);
   lcd_data(c);
//test
main()
   LCD_E_PIN = 1;          //init LCD1
   LCD_E_PIN = 2;          //init LCD2
   LCD_E_PIN = 3;          //init LCD3
   LCD_E_PIN = 1;
   lcd_clrscr();
   lcd_puts("DISP 1");
   LCD_E_PIN = 2;
   lcd_clrscr();
   lcd_puts("DISP 2");
   LCD_E_PIN = 3;
   lcd_clrscr();
   lcd_puts("DISP 3");
   for(;;)
I see I see makes sense...I never thought about that before!!! I will try and see how it works!!!
With separate inits for each display, I would move the big delay out of the init since it would only be needed once.
Steve A.
I have it all working now thanks ......any clue why the enable lines show up at bit 1 bit 3 and bit 4
I have these for the corrisponding bits
PORTA |= _BV(1)....shows up at bit 1, PA0
PORTA |= _BV(2)....shows up at bit 4, PA3
PORTA |= _BV(3)....shows up at bit 3, PA2
Which AVR?
What is PIN 0 ? Pins on AVR count from 1.
ATMega 32, and sorry I meant to right PA0, PA3, PA2
