ATMEGA8 PWM OC2 Not working
5 posts / 0 new
Hi guys!
I have trouble with OC2 output pin.
The code below, working on ATMEGA32 but not with ATMEGA8! and I can't see the problem!
Can anybody help me to found the mistake?
Thanks in advance!
Fabian.
#include
#include
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
volatile unsigned char DutyCicle = 0x00;
void PWMInit(unsigned char count)
    // Enable timer0 compare interrupt
	TIMSK = (1<<OCIE2);
	// Sets the compare value
	OCR2 = count;
	//FAST PWM mode
	//CLEAR OC2 on MATCH
	//Prescaller Fclk/8
	//For ATMEGA32
	//TCCR2 = (0<<FOC2)|(1<<WGM21)|(1<<WGM20)|(1<<COM21)|(0<<COM20)|(0<<CS20)|(1<<CS21)|(0<<CS22);
	//For ATMEGA8
ISR(TIMER2_COMP_vect)
	//OCR2 = DutyCicle;
	return;
	//DDRD |= (1<<PD7);	//For ATMEGA32
	DDRD |= (1<<PB3);	//For ATMEGA8
	DDRD &= ~(1<<PD6);	//KEY +
	DDRD &= ~(1<<PD0);	//KEY -
	PWMInit(0x7F);	//50%
		if (!CHECKBIT(PIND, PD6))
			while (!CHECKBIT(PIND, PD6));
				DutyCicle++;
		if (!CHECKBIT(PIND, PD0))
			while (!CHECKBIT(PIND, PD0));
				DutyCicle--;
		OCR2 = DutyCicle;
Timers in AVRs can generate a PWM-signal without the need for an interrupt.
In your code I don't see where the used AVR is defined.
A GIF is worth a thousend words   They are called Rosa, Sylvia and Tessa, You can find them https://www.linuxmint.com/
Hi!
thanks for you ans.
Is defined in project configuration options.
Yes! i know! is another test in my confution!
Thanks.
Resolved!!!
here the mistake!
	DDRB |= (1<<PB3);	//For ATMEGA8
Is PORTB not PORTD. :(
THANKS!!!
Good ! Congratulations :)
Your While-loop executes in a few microseconds, so incrementing or decrementing takes place very fast .... much faster than you can release the button. You can add a delay() in the loop for test-purposes. Have fun !
